Ok another stupid question.... I am configuring my C7 hub that I have had for a while now. I want to add it to my hub mesh but the hub mesh tokens on all of the other hubs are truncated on the Hub Mesh configuration screen and I can't see the entire token to copy it to the new hub so that it can be included in the mesh. Is the entire token visible somewhere else where I can copy it?
Did you try resizing the browser window? Alternatively, you could double click on the token, which selects the entire string, and then do a copy.
I did both.......
You tried both approaches and were not able to copy the full token?
Your display is too small to allow a browser window wide enough to see the full 64 bytes of token? I guess I can see that, but the double click and copy approach should work regardless. I tested Safari, Chrome and FireFox and double click and copy works in all three. What browser are you using?
U used it on another Mac with a wider resolution display and got it... Thanks....
When adding a hub token to another hub, the dialog has a clickable link that will display the token in a new tab without all the other UI fluff. The link is behind the UI security "wall".
How do you get to that for future use?
Two ways:
- In a section on Hub Mesh page, towards the bottom.
- Direct link at http://your.hubs.ip.here/device/showHubMeshToken
