I have a custom device and don't know all the attributes provided.
It is a basic analog device. I found the below table which does not shot anything that could be construed to be an address, yet the code I copied from seems to thing there is such an attribute.
So I was trying to add a bit of debug code to list all that is there. My attempt is the below line with all the = signs. However this code results in a null pointer exception.
Am I close or way off the track?
if (descMap.cluster == "000C" && descMap.attrId == "0055"){ // zigbee spec 0x000C= read analog cluster 0x0055 = present value
descMap.each{ k, v -> debug.info "${k}:${v}"} <<========================
BMEhexData = descMap.value
SensorValue = ConvertHexToFloat(BMEhexData) // <--- value as float
def otherAttrs = descMap?.additionalAttrs
otherAttrs.each{
BMEunitaddress = it.value
