I.have the redlink hub with no issues
I think whatever your problem your barking up the wring tree.
Hello
Do you know if this can be made to work from the UK or if anyone has written a version for the UK? I did try registering my thermostat on the USA site that sort of worked but ended up being problematic in other ways,
The sites are different for the USA (Honeywell Home - My Total Connect Comfort) and the UK (Home | Total Connect Comfort International)
I have a simple setup with just a Honeywell round thermostat but would be handy to control from Hubitat.
Yes thereâs an unmaintained UK version. There are a few issues with it. Thereâs no option to switch off info logging - I messed around in the code a bit, commenting out a few lines to avoid filling the logs. Also I think some of the driver capabilities arenât correct or donât align with the standard ones for thermostat. As we are Heat only in the UK it doesnât work with most dashboard thermostat tiles (though it does in SharpTools for some reason). Apart from that itâs fine. I use it in rules to drop the heat to 5C in rooms when doors/windows are open and resume when closed. Iâll see if I can find a link. I posted my revised code on this forum some time ago.
Thanks, that should be all I need, just want some fairly basic controls and to be able to turn it on and off from one place! And luckily it is a sharptools that I use.
Here is a link to the thread where I've linked the app code and driver code. It's an age since I first installed this it but I'll try and also locate/link the original post that has more details of installation:
From memory, you:
- install the app code - Apps Code > New App > paste the code > enable oath > click save
- install the driver code - Drivers Code > New driver > paste the code and save
- install the app - Apps > Add User App > Select 'Evohome (Connect)' and install it
- enter your username and password that you use in the Honeywell app
- go to your device list and the thermostats should be there
Mine is the zoned version of the system working off individual valves. When you log into your account in the Evohome (Connect) app it creates child devices for each zone using the driver that was added. As yours is a single thermostat I assume it just might create a single device.
Edit: There's further information in the thread linked below starting at post #19:
Thanks for that, installed ok and it does create the thermostat, can read the temp and see the setpoints but at the moment can't seem to adjust anything or use boost, but it is definitely doing something!
Thanks again for your time
I've just had a look at one of my zones in devices. Strangely I'm sure that in the commands part of the page, I used to be able to enter a value in 'setHeatingSetpoint' and I could send the command like that, however now there's no longer a space to key that value in. It could be something I've inadvertently broke when messing around in the code. I don't think 'Boost' and 'Suppress' ever worked for me.
The things that should work are the Auto, Away, Custom, Day Off, Economy functions. I've created virtual switches for some of those. I've a rule that triggers if any of those switches are used that sends the custom command to the device so that I can have those switches on my dashboards. Here is the rule I did for that:
I use the 'resume' command in my Goodnight routine. If I've overridden the temperature manually either at the radiator (thermostat in your case) that will put it back to its normal scheduled temperature:
The capability of the device is Temperature rather than Thermostat. I seem to recall when you add a tile to a SharpTools dash, you add the tile as temperature, then change the layout to thermostat to get a single height tile showing the set point with functional up/down arrows. I can't get a tile to work correctly in other dashboard apps such as HD+ which I'm using and I believe it's because of the driver not using standard methods (all above my head TBH). To get around that I've added a Button Controller instance that gives me a four button tile for commonly used temperatures that maps 18, 20, 22 degrees set points and a resume.
Unfortunately, even though it seems to have installed ok and does read the temp ok it doesn't seem to be able to send anything! Created tile in Sharptools which seems to talk to HE ok but nothing after that.
Logging showing that it is unable to update but nothing more useful to me I am afraid!
Think I have sorted the problems I was having, I had not set the app for any specific modes! Seems to be sending things across now...
Doh
Hi @csteele
I bought new thermostats for my house, the latest Honewywell models, and they are having problems receiving status. I see that they are logging into the Honeywell APP, but it doesn't return the information.
dev:3292023-09-01 10:57:21.394 AMerrorgroovy.json.JsonException: Lexing failed on line: 1, column: 1, while reading '<', no possible valid JSON value or punctuation could be recognized. on line 369 (method getStatusHandler)
dev:3292023-09-01 10:57:19.636 AMdebugsending getStatus request
dev:3292023-09-01 10:57:19.635 AMdebugenable outside temps = No
dev:3292023-09-01 10:57:19.635 AMdebugHoneywell TCC getStatus
dev:3292023-09-01 10:57:19.634 AMdebugin get humid status enable humidity = No
dev:3292023-09-01 10:57:19.631 AMdebugAdding cookie to collection: thlang=en-US
dev:3292023-09-01 10:57:19.624 AMdebugAdding cookie to collection: .ASPXAUTH_TRUEHOME_RT=cgNHo-r1twMmEarGXNLnUcz9hfTicJIaa2NB91IVBpPO494sMpxr1ISrz1V7ayYvrIkSEikhVwY03GcdsSHjgwleZeu62QdRQyREMqT9r06gS0QeAdCMsyW5tIkNr9VSq1RqXn_APGCnN1PEl1xNrvpitvVS0jynq3crbBpziZ9dClR6cwveYVNTN0Yiydw3ZV0xczXcokd1WkG9iR4XcO0U1dnoBxrJlgyW3zNXh_VGv3Zu1-31-1rbVzwvvt7yKD0EBLPvXDFctfmPEv0IQF0--GSPhgWK3W9eDu8DncTV2-BQcb0eZEVCb7D5Gj_rSpGh0bllcKjP8EUiP3sCEnB6Nl698kXJlMDPFqZ7GpjqjtEgD33sOQcvqQvG4SrlvwUe9D1XMX1qmtROt3YULqmR2Tl_ySnsM7cONNz08JZOcjlGsKxYdaTbY8NdOAcq1k-idx4W-L02IzK1I3piGGbbD7ZGtjW7YVAoIKX008QjyBZZcztN1N8bfx-9ZOUy_Tu2Dyy2o1Tixmnx9VMI-MwlcbSdATzrfrDj9INxASYrK62aUK_eOtDHCqfRqpc6wKhuinZDFJjeIp_4An2-HyIyf656H9O_qPIA41xck-gOQwBEKyC5W4oW7iHsNjqEXS0Quk6yqvBsRlY93JfjwfJnAYxfEXGvlOIDGG1eWqRvCk02RXqiBRk1OvTQKmzCgycmGA
dev:3292023-09-01 10:57:19.617 AMdebugAdding cookie to collection: .ASPXAUTH_TRUEHOME_AT=_YlIO875UQVzTlbmYeryvzZRRyhT5QldZn5PTdkuXHGDJmqu3XsSGnpyTmRvx5Vx8LUcmulOkL9vXO-frXHQzDH9U3ZR0mst-nnY0prLyyE4hWEx_WkZXwhLRETWcd0sCwMhI4Rm0JqguBgDuj_BqiaMCZAf42xxAKWzACFgJASnQhs3bO9fYTuafomednut2DRyevRe-15lniDUdpL9oqUvIhhRwK7YJWJUYXwqVSYpjCG6_ByeP7akNjchsyKyy4nKRSO5nRog5gcgr9ddaMsZMQm03GA63turoHbsnBRZwf7Z8DTjCFSM-j2jZtIbR2wzwZZNgF9R3hHSuoQDyqJ-KKhJN47Bvqpj_bxox8-B3x5dqsxdf9obJPCOKLs3xaTnw6HP5GQVPdWAboz8siDkYVO210yNXnrzi6bNfkr3laC4fwoDmSnJYcJTQgVJcM2MGPXjWGPJXlHHiKq1EOJNzvqqo24dLu6glJBXbYWoL04cXczQwl_MUEAC43W-KjZIXbuQR5_d0nvHVuqLLaA55_8PI5Ju-KMd2X6991dWnGlPntpy-28Uv6LtbZvZi7XIG9MRozUFtcSjOGkR9wBGafXAgA0_vATuaYgHeqla3iLuD5l6YJXm_bWHYzbn907U_N5X8fwhUcwe0UTSKDB1s6BazM0z8qaRFrLp4jvNv9fBicRIiyMOIbg0kvZ11E94Hg
dev:3292023-09-01 10:57:19.567 AMdebugAdding cookie to collection: .ASPXAUTH_TRUEHOME=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
dev:3292023-09-01 10:57:19.564 AMdebugAdding cookie to collection: ADRUM_BT1=R:0|i:197975|e:78
dev:3292023-09-01 10:57:19.562 AMdebugAdding cookie to collection: SameSite=None
dev:3292023-09-01 10:57:19.560 AMdebugAdding cookie to collection: ADRUM_BTa=R:0|g:88655516-ef08-4e5d-ad3c-c35b73647b27|n:honeywell-prod_f7be1c76-506d-4111-81c5-fc62766aedb7
dev:3292023-09-01 10:57:19.558 AMdebugAdding cookie to collection: ASP.NET_SessionId=nggw1chngqqgbp4wlqp3au1w
dev:3292023-09-01 10:57:19.556 AMdebugRequest was successful, 302
dev:3292023-09-01 10:57:19.062 AMdebugHoneywell TCC 'login'
dev:3292023-09-01 10:57:19.061 AMdebughere Honeywell TCC 'refresh', pollInterval: 300, unit: = °C, fromUnauth = false
dev:3292023-09-01 10:57:19.060 AMinfoin poll: (every 300 seconds)
dev:3292023-09-01 10:57:19.025 AMdebugPermHold now = 1
dev:3292023-09-01 10:57:19.006 AMinfodescription logging is: true
dev:3292023-09-01 10:57:19.005 AMdebugdebug logging is: true
dev:3292023-09-01 10:57:19.004 AMdebugin updated
Please, could you help me?
I can't see enough to assist. What I think I'm seeing is that the JSON returned inside the communications with Honeywell's cloud, has unexpected data. It's not pure JSON perhaps. Hard to guess with the info provided.
The only Thermostat I own is the older RTH65xx series:
I have seen people report that you model: RTH9585wf does work with my driver:
Yours might be newer and have new JSON values.
I'll add purchasing a RTH9585wf to my list of To-Do's, maybe my family want a new look Thermostat ![]()
Might add a line to the getStatusHandler to throw the JSON into the logs,
def getStatusHandler(resp, data) {
if(resp.getStatus() == 200 || resp.getStatus() == 207) {
log.debug "${resp.data}" //insert this line
def setStatusResult = parseJson(resp.data)
Hi @thebearmay
Log with the change
dev:3292023-09-01 03:07:24.392 PMerrorgroovy.json.JsonException: Lexing failed on line: 1, column: 1, while reading '<', no possible valid JSON value or punctuation could be recognized. on line 370 (method getStatusHandler)
dev:3292023-09-01 03:07:23.383 PMdebug
HoneywellHome.com
target="_blank">
Contact Us
FAQs
My Account
Control Center
Sign Out
Welcome
Leonardo
Unexpected Error
This site will not operate without Cookies enabled. Refer to the FAQs tab on this site to learn about enabling Cookies for your browser.
Unexpected Error
Error
Error
Sorry, an error occurred while processing your request.
Home
Version 2.11.13 - July 06, 2023
Privacy Statement and End User License Agreement
Terms & Conditions
Global Site
Feedback
2023
Resideo Technologies, Inc.
The Honeywell Home trademark is used under license from Honeywell International Inc. All rights reserved.
English
Français
dev:3292023-09-01 03:07:22.614 PMdebugsending getStatus request
dev:3292023-09-01 03:07:22.613 PMdebugenable outside temps = No
dev:3292023-09-01 03:07:22.612 PMdebugHoneywell TCC getStatus
dev:3292023-09-01 03:07:22.611 PMdebugin get humid status enable humidity = No
dev:3292023-09-01 03:07:22.608 PMdebugAdding cookie to collection: thlang=en-US
dev:3292023-09-01 03:07:22.602 PMdebugAdding cookie to collection: .ASPXAUTH_TRUEHOME_RT=1ks0v7roC0kq4sliT71NSNt9-NpBfmOB0pspG-bv90pobIlteBRAgxsgMeaA1LqM3_biAZ2oA1th1KKUSv_fX2BGaNsl80GJHmdbjNwTronivB9aXZ04KoYreEcvkBv2Gyk698WZO5lIutFgtsbZFzuu96uBb--xeKkXHfqMnyr8MefZ1YmrZVx80lK7f9iP0FBeYlDyS1nP_CKhQEARXIxrRVrqGExAYcWzcLr7j-rW1zR0JK-CbKKSkEn-XQqKMHVBfCb4FTVSMGsqnMgMp-nqLmExnIZyLa9XVSlGPAaoMv5uGLptIVZVVyF5dZe6IkoIzzVgPAiHoUScTf5D4n56jOZfpKNxznpL1BtaH_YbPPxi2oH1dBguMqiBag4Vsar8BY4yiDAGpby2UCJNAq44OY5oTQoKbOf8lTEhE7hYGo403PDJfBHkOFJMhGKecqAsFcLPAVQyHbgsYmCag2UgDBP3FHLMFTcMP9hp441xl4B-V1o-T9uKd2PPKUOXDKJWNQh-SmbcFy2GQcgrk8Jo-oj3t9_IurZwSCSCMGhmyCj6_w3dBmSHkRCK7hWYuxoZKMQ7QLv4qRGkAdX1zHe9C1SuEm_xJHd64p3MIWGGR-1ux7vEuq3NqK1H9xaoaGwbHtQDBdrB09gP5_bgN0SPBMor98F1Gr8xNtDoFOdGx5pe7UxiII-t9YMacHGkTMUtGg
dev:3292023-09-01 03:07:22.595 PMdebugAdding cookie to collection: .ASPXAUTH_TRUEHOME_AT=qeyLLLG8TwXfbAXtXnNYeXIN0rb2fvixmBvmtvc9jiWt-74jcSKsraS6KmQEDT7ckTLnbsduh9_Bpcw9Qu7bt7CU1L_gzkT4YZN_pAWek7h0IlqkQcp_Olx7SUSW1LiWqmOcaUIu61NBpJ-nFQm5rNQr_uncSndeS_w-z-4rCX8j18fA0F9jj3u22hQgB-N-dhhXI6MffMj3ZRvwlzxEECZtwBf3R3wm9Ps1aiq5P4xG4iEBUWVi9JVPOmM5qft60wahet7KNxn9uKMxpftUO0yaOJahAx3TCVNZV61C4pcWrRa7YXQAwSHwLWzMTU0paHmfJRA2jWbY4hM0M8z2ZS_ckNJi7mwBEDk2hLhhSHa4Fn5jja_brVm8tSgTo822qcl5ZNQ5Hoy0OFTALp0KGTzDGk1e9EzpOIULkv7xjB0UqUrSFXO-uqSfcDS-BwZLfFk5Yw0I_9rBhPEgkmjADileodh5sq1r4wGli4KKBiuj35O8EiYrZdmIwQeFcLCg79z4ATHGtuKwGh5NjsdfMmQ1rR5qYYMzGX8ExHjriHeGM5iTx1FIfLkW9Rk4Rpcg6AknVrJcws-wU3UtK4HBUl7CigSXTCDI95eBwA9OybaT8l1NTWUSHl6ln6MV_OTdvaKVVoLkxnIR4NOnUa1JWhCjRwJgRWGMeXk-5oGWVksxdFFYhIOawUfsFPGOEOkUsFcYrg
dev:3292023-09-01 03:07:22.587 PMdebugAdding cookie to collection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
dev:3292023-09-01 03:07:22.585 PMdebugAdding cookie to collection: ADRUM_BT1=R:0|i:197975|e:106
dev:3292023-09-01 03:07:22.578 PMdebugAdding cookie to collection: SameSite=None
dev:3292023-09-01 03:07:22.575 PMdebugAdding cookie to collection: ADRUM_BTa=R:0|g:a04efac9-27c7-458f-8acb-655afe6dd5b0|n:honeywell-prod_f7be1c76-506d-4111-81c5-fc62766aedb7
dev:3292023-09-01 03:07:22.573 PMdebugAdding cookie to collection: ASP.NET_SessionId=xg4ra0lyows0ar00lqnkevki
dev:3292023-09-01 03:07:22.571 PMdebugRequest was successful, 302
dev:3292023-09-01 03:07:22.068 PMdebugHoneywell TCC 'login'
dev:3292023-09-01 03:07:16.065 PMdebugAdding cookie to collection: ADRUM_BT1=R:0|i:197975|e:220
dev:3292023-09-01 03:07:16.064 PMdebugAdding cookie to collection: SameSite=None
dev:3292023-09-01 03:07:16.061 PMdebugAdding cookie to collection: ADRUM_BTa=R:0|g:f2d88de8-62f9-492e-b5c2-2c29b8def864|n:honeywell-prod_f7be1c76-506d-4111-81c5-fc62766aedb7
dev:3292023-09-01 03:07:16.059 PMdebugAdding cookie to collection: ASP.NET_SessionId=4sntvha22cn5fao5tkuk5s50
dev:3292023-09-01 03:07:16.057 PMdebugRequest was successful, 302
dev:3292023-09-01 03:07:15.604 PMdebugHoneywell TCC 'login'
dev:3292023-09-01 03:07:15.603 PMdebughere Honeywell TCC 'refresh', pollInterval: 300, unit: = °C, fromUnauth = false
dev:3292023-09-01 03:07:15.602 PMinfoin poll: (every 300 seconds)
dev:3292023-09-01 03:07:15.566 PMdebugPermHold now = 1
dev:3292023-09-01 03:07:15.548 PMinfodescription logging is: true
dev:3292023-09-01 03:07:15.547 PMdebugdebug logging is: true
dev:3292023-09-01 03:07:15.545 PMdebugin updated
Let me try it out with your drive and return. Thank you.
Hmmm that would explain the parsing error - resp.data is either not being returned or empty. Can you change it to resp.properties ?
Ok, now with the change.
dev:3292023-09-01 03:39:02.135 PMerrorgroovy.json.JsonException: Lexing failed on line: 1, column: 1, while reading '<', no possible valid JSON value or punctuation could be recognized. on line 370 (method getStatusHandler)
dev:3292023-09-01 03:39:00.076 PMdebug[headers:[Server:Microsoft-IIS/8.5, Pragma:no-cache, Date:Fri, 01 Sep 2023 20:38:57 GMT, ADRUM_1:n:honeywell-prod_f7be1c76-506d-4111-81c5-fc62766aedb7, X-Frame-Options:DENY, ADRUM_0:g:f7ad0984-ec73-4842-ba9c-45998ced6c37, X-UA-Compatible:IE=edge, ADRUM_3:e:31, ADRUM_2:i:197987, Cache-Control:no-cache, no-store, must-revalidate, Set-Cookie:NSC_NZUDD-443-WT=ffffffff090ecc0345525d5f4f58455e445a4a42378b;expires=Fri, 01-Sep-2023 20:36:04 GMT;path=/;secure;httponly, Expires:-1, X-XSS-Protection:1; mode=block, Content-Length:11646, Content-Type:text/html; charset=utf-8], warningMessages:[], class:class hubitat.scheduling.AsyncResponse, status:200, data:
HoneywellHome.com
target="_blank">
Contact Us
FAQs
My Account
Control Center
Sign Out
Welcome
Leonardo
Unexpected Error
Unexpected Error
Error
Error
Home
Terms & Conditions
Global Site
Feedback
2023
English
Français
dev:3292023-09-01 03:39:01.979 PMerrorgroovy.json.JsonException: Lexing failed on line: 1, column: 1, while reading '<', no possible valid JSON value or punctuation could be recognized. on line 370 (method getStatusHandler)
dev:3292023-09-01 03:38:59.412 PMdebug[headers:[Server:Microsoft-IIS/8.5, Pragma:no-cache, Date:Fri, 01 Sep 2023 20:38:58 GMT, ADRUM_1:n:honeywell-prod_f7be1c76-506d-4111-81c5-fc62766aedb7, X-Frame-Options:DENY, ADRUM_0:g:a21dbe6f-ee91-4c99-bcff-bc4de46333f3, X-UA-Compatible:IE=edge, ADRUM_3:e:31, ADRUM_2:i:197987, Cache-Control:no-cache, no-store, must-revalidate, Set-Cookie:NSC_NZUDD-443-WT=ffffffff090ecc0745525d5f4f58455e445a4a42378b;expires=Fri, 01-Sep-2023 20:36:05 GMT;path=/;secure;httponly, Expires:-1, X-XSS-Protection:1; mode=block, Content-Length:11646, Content-Type:text/html; charset=utf-8], warningMessages:[], class:class hubitat.scheduling.AsyncResponse, status:200, data:
HoneywellHome.com
target="_blank">
Contact Us
FAQs
My Account
Control Center
Sign Out
Welcome
Leonardo
Unexpected Error
Unexpected Error
Error
Error
Home
Terms & Conditions
Global Site
Feedback
2023
English
Français
dev:3292023-09-01 03:38:58.523 PMdebugsending getStatus request
dev:3292023-09-01 03:38:58.522 PMdebugenable outside temps = No
dev:3292023-09-01 03:38:58.521 PMdebugHoneywell TCC getStatus
dev:3292023-09-01 03:38:58.520 PMdebugin get humid status enable humidity = No
dev:3292023-09-01 03:38:58.517 PMdebugAdding cookie to collection: thlang=en-US
dev:3292023-09-01 03:38:58.503 PMdebugAdding cookie to collection: .ASPXAUTH_TRUEHOME_RT=InNaXSdUkFbknx3a6ilNPU-qoaHVuft0GQGmz2mqMvg5LRt-CfLJjeZEPHPw0RAQrgjuNMFhO6CxgOMfOQd9oEy0pegw7uICg7sO6SbhxOciRmTqxyvVWT8tA_2XRYn0HMdmywnbFJyIdwIAWMq2Fo87uQss4vFDeOImbgJdtfcL9yDEsRsoHQaPilZ41t2oIQO6DKxkjM1jLSWHBvG_x87jWpYe50cYBUMmMA_t8TclXwc0Ch6spzS3otGA4ibuBG1NIFW_jKl39VhVGrXzLf2OdWgIjefBsu0HdF_9nGdqQoFxXIivbpElYjMjtdm3a98s8YlYIS2RPAmHwmEs6W0ek3d3yHRYKK_XhcUow5XNYNTI2bHSUxgmU_9AggkI0XMG_lGUs75nvihgqatamnb3nPLGNY140S4JdLlDqfomh7hgH_Z6M64iEnKqqcGBICt6x3stkrtDouRG40-HIptCwsGljW6L8u8FBzS2w5P4X6f_rv2D3Lak1BJPFwxwc1SU-VEXZ9QbyVUGzIpMp9km9XWnG7JpqAeTjdjzH2DAf3XggOkjLzPREJzMXeslhp1c1fK3iax8NPD41AshtPdlpZuyaVh6iieXNa55PQf9hmBmmMNHObT5ryZYQ8eKhgSJNSO059ELkjmc68LQ2SW6CxBVgYttfPVyG0vq4xIu253up-m4HDe0xwa4tg-dqEfi4w
dev:3292023-09-01 03:38:58.492 PMdebugAdding cookie to collection: .ASPXAUTH_TRUEHOME_AT=LaO62aShTdQNJSBF_D7pwbjuM_GRV8eUmi145LxBn237IEcVpuNOhg85O9CvqFAqchwHEIZzXsxAdIA2wXBUz9we7bA31wjJR-nEqAXaz3oe5N5KeoOinFLLCVEpc8MJPTdXXLbkviCTFvwOMP1byY1y3sCqNSitl3W7lz-oHHypEXv1tEOYZ_PlmQOu-SvXk602Mq_W97aUiEILOfLniZ9AqFZwMxv1uvfU2tscPZScwZLScBkKNxYVhDrrw4_gSCDrKWJHD11_jHa6D94gDVHrKsO-slwkr8vjS327O1xOblWTlvFMdr1zBe_LlnP5fDghuJypAz2gFO9Kf8mHI7tOe-8l9eqMH6YBxUmTFjMup4aa7GVc-qfUnb6yxxqd1kLjuy81u_C1CnSod6MVh7j78BjLgZ_pOC01AChkvUSqeodj7BboiHkKX1wYcS4qdhBGe9AE79lcGpNB8aRJUrYtAc7kKXToCX_oshqjJBTl7eaWiKvLrI5Kds5CpT3KPRqpYMKUnFzxNtFbvEJAQ6VghmLTKNRn6mIh5PGSFgze4QT7ADJCNRMDIbZf9A83X5HDFcK3U3h3LWMxdSNWTU8mZkESWssOaY5AAN4YT3UOypKZinE7QCA1WiWfkd79Jz3IgTYHg9tMy2g93Fzypnrp3Zt73xZj2fbofJM2vIGn8ulJdyBXpEApcaQXdVVB_xiocg
dev:3292023-09-01 03:38:58.485 PMdebugAdding cookie to collection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
dev:3292023-09-01 03:38:58.482 PMdebugAdding cookie to collection: ADRUM_BT1=R:0|i:197975|e:21
dev:3292023-09-01 03:38:58.460 PMdebugAdding cookie to collection: SameSite=None
dev:3292023-09-01 03:38:58.458 PMdebugAdding cookie to collection: ADRUM_BTa=R:0|g:2b402ac6-b41a-4de7-9c87-f9870276fc0c|n:honeywell-prod_f7be1c76-506d-4111-81c5-fc62766aedb7
dev:3292023-09-01 03:38:58.455 PMdebugAdding cookie to collection: ASP.NET_SessionId=2w02qiizmzbrp0lc0wmikldk
dev:3292023-09-01 03:38:58.453 PMdebugRequest was successful, 302
dev:3292023-09-01 03:38:57.938 PMdebugHoneywell TCC 'login'
dev:3292023-09-01 03:38:57.937 PMdebughere Honeywell TCC 'refresh', pollInterval: 300, unit: = °C, fromUnauth = false
dev:3292023-09-01 03:38:57.936 PMinfoin poll: (every 300 seconds)
dev:3292023-09-01 03:38:57.897 PMdebugPermHold now = 1
dev:3292023-09-01 03:38:57.877 PMinfodescription logging is: true
dev:3292023-09-01 03:38:57.875 PMdebugdebug logging is: true
dev:3292023-09-01 03:38:57.874 PMdebugin updated
dev:3292023-09-01 03:38:57.560 PMdebugsending getStatus request
dev:3292023-09-01 03:38:57.559 PMdebugenable outside temps = No
dev:3292023-09-01 03:38:57.558 PMdebugHoneywell TCC getStatus
dev:3292023-09-01 03:38:57.557 PMdebugin get humid status enable humidity = No
dev:3292023-09-01 03:38:57.555 PMdebugAdding cookie to collection: thlang=en-US
dev:3292023-09-01 03:38:57.548 PMdebugAdding cookie to collection: .ASPXAUTH_TRUEHOME_RT=CmoS2j3pxDZxZpMU9SOPcNGxmw4S_I2iV3cnC_TXUXr9WycmUw5NqceifJm5pnE4DMquteLXvPTqL170lwposRr0j2pndWjdMPoec761mxtdLyTWfCApRVGbTKvnNQfIZdP0XP5ebmRXI3iY2vKLXkrnhSgJeKmVW2KPh9caaib7dWznlQmQESMMTENHK-8TTz6iNTrPj3mgzZt4loxfqylXEBvRFKt2qOdkyYOq9GODhlDkqDCvwZmstJF1u9LpmpBrmrSeSamkxHAKn6L-P8y5FpxPIUFcVbKsXqkK_HdEEYKUxOIyjfzfyawGmGkHbs0H_vQR4cwvWMCqY1LV5QkviOlRnUqul2q07TumWzv2TfPoaJ6mGHr66sptiUIaEwMUU-CdP6iwa8WadsW47F3ZdWksYFm0NZ2eqPuDNhreOD0oMOqszscAxJPn2uGiI71zxdNxAffclxjlYW57h0GJ0TI5YpjRdj5MmQZKZAHBjT01yE08wAzG_PiedoBHEPIwOQwqLR5EokeeMvyQDgr8noHQ4D9KiT95oJfB742OQrZ9hKXtOoN5z7hi2zq1SyO8qvin5oML_uKEKf2HPBjvTa_KjD_UZ3TD9c-6QvhTieid25x-3Blfg1Ako9jitBYPTp-meBfbzPA1s_8SPYvaOFYaTswT4KPHz6eoYyyKJ0VheTw9fg-dc9fbMxL3SgeW2w
dev:3292023-09-01 03:38:57.541 PMdebugAdding cookie to collection: .ASPXAUTH_TRUEHOME_AT=bUe_bFhrgxPgS40ISD-fLDU02h1fMMMX2kFs3vFcBRCBZ0Ppu-ml903Z8CqjG2BuhlBm5TjCkrFVeBbRefoOkzFfSqQLxwpaVANkYsSsDwmlwVQj663RLTixl7VgMQoEBU6btoIComVf5oe6Ere2waKbl59_D0sC1vMM-E7soeMy5ymdaq36V1ReO_OacssMNk9Qylnxt2XhUcS-HEmStySBzKX2GUuV4aZ8mSAyvt5VNz_pexDJVcj0BAfqCdJficfDyZGWcyYzE7-kyj-ZfcWt6q83k155LQlGirIYm23CrEr5S2ysgea_55GNKnbkwD0a84UvLnCQUfpo3K6DQmxXV07RMLkIX7UFrZydQwz-pnBqCLFhr-iPcIC3yPkO6wwA9uUl2MGWhOL21qq1eIZU1W-YtUdwX7Vg8Q0SAtlUuEMTj2SO8khfA8BOxWSAHVOiIiJfSa1vpTUWlm8yrjiMubm7vZ440hJW0Q1sm-v5hB86fEbewj8F0VSUimzwx75G5tv7aBE0xU9OTeezBwYmANVIA5KsM6tYQHnwF6mNuA_rAaI5UMYGf_8X7OjRVq6y-A8wa-VJOvsCNwugGcq--TZrHdp6oSDSgXH2ZXvyv7KMNunaY-z0z5Kc2fMsx0bAfOGL5QMyzkjoRviNa8B_073nt__tcwxJ5_Ql4hULQz5PW52b3fgWyX8WnE4jzTJGTQ
dev:3292023-09-01 03:38:57.534 PMdebugAdding cookie to collection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
dev:3292023-09-01 03:38:57.532 PMdebugAdding cookie to collection: ADRUM_BT1=R:0|i:197975|e:18
dev:3292023-09-01 03:38:57.530 PMdebugAdding cookie to collection: SameSite=None
dev:3292023-09-01 03:38:57.527 PMdebugAdding cookie to collection: ADRUM_BTa=R:0|g:27cc4f8d-2a7c-42bb-9095-3a76de8c84d0|n:honeywell-prod_f7be1c76-506d-4111-81c5-fc62766aedb7
dev:3292023-09-01 03:38:57.525 PMdebugAdding cookie to collection: ASP.NET_SessionId=eybzynvrfsiddoqpaizetqvc
dev:3292023-09-01 03:38:57.523 PMdebugRequest was successful, 302
dev:3292023-09-01 03:38:56.939 PMdebugHoneywell TCC 'login'
dev:3292023-09-01 03:38:50.936 PMdebugAdding cookie to collection: TrueHomeCheckCookie=
dev:3292023-09-01 03:38:50.934 PMdebugAdding cookie to collection: ADRUM_BT1=R:0|i:197975|e:23
dev:3292023-09-01 03:38:50.932 PMdebugAdding cookie to collection: SameSite=None
dev:3292023-09-01 03:38:50.930 PMdebugAdding cookie to collection: ADRUM_BTa=R:0|g:54affaae-2598-41a5-9470-264b3cd11d21|n:honeywell-prod_f7be1c76-506d-4111-81c5-fc62766aedb7
dev:3292023-09-01 03:38:50.926 PMdebugAdding cookie to collection: ASP.NET_SessionId=shpwa5lmmtqcboboyica5u0k
dev:3292023-09-01 03:38:50.923 PMdebugRequest was successful, 200
dev:3292023-09-01 03:38:50.321 PMdebugHoneywell TCC 'login'
dev:3292023-09-01 03:38:50.320 PMdebughere Honeywell TCC 'refresh', pollInterval: 300, unit: = °C, fromUnauth = false
dev:3292023-09-01 03:38:50.318 PMinfoin poll: (every 300 seconds)
dev:3292023-09-01 03:38:50.283 PMinfoInitialize Poll
Hi @thebearmay
Was it possible to check something?
Can I help you with more information?
Thank you
Looks like the app needs to set a cookie and couldnât
Where are you located, please? The standard Honeywell site is "mytotalconnectcomfort.com" and the message you receive is from "honeywellhome.com" which is not the expected response.
Two possibilities:
- The URL was changed in the driver.
- Honeywell is redirecting.
A "normal" log output would look similar to this:
dev:24712023-09-02 04:58:54.875 PM debug sending getStatus request [uri:https://mytotalconnectcomfort.com/portal/Device/CheckDataSession/xxxxxx, headers:[Accept:*/*, DNT:1, Cache:false, dataType:json, Accept-Encoding:plain, Cache-Control:max-age=0, Accept-Language:en-US,en,q=0.8, Connection:keep-alive, Referer:https://mytotalconnectcomfort.com/portal, X-Requested-With:XMLHttpRequest, User-Agent:Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/28.0.1500.95 Safari/537.36, Cookie:ASP.NET_SessionId=3ijvpk1zmq4ucmaia0jqqbq2;ADRUM_BTa=R:0|g:cbfdbd78-6e91-4fb2-94dc-264e7d90e1f1|n:honeywell-prod_f7be1c76-506d-4111-81c5-fc62766aedb7;SameSite=None;ADRUM_BT1=R:0|i:197975|e:149;.ASPXAUTH_TRUEHOME=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;.ASPXAUTH_TRUEHOME_AT=-AKfcKmPNT0e-uhsR7Yz_f3KiVyzexKFhAVUt8421nCsTQ2mbJJZilnG943rE92FRWUn1zN2rr2sOLam5jpV6K7QNvsspTNm1YYLneXJIbLzp5eORdOQBfUOTZsFsJIQ7Jb7XvkungpzNbJCTBe6wx0uGvlU-tjy7W2czNre0zRHRyBmzBQbmEC1qlQnMS5KBk0Z8FMRF5UZXuiLZaYjqk40kscY8sde9s-NW_s8TgQcUC2iR5hqC4iOA2CCkDyII6CoiZ9rHjFEXWpc7qE5jsGnkdAyXd9uGXVhvis-IrkCUGpEEvC8zm2YyuoOxxE4KB3931A3gRfgSmlrjoi97C02532eR-VdWCFGQrnisuHx2nwVPYRRhbDnptF5F6qfwc3TDyWtlB4HEtQBkyEjo-s3qZxWiQUMd1_LrGqDlj4MFvikDfubfOSmjbFRf7utz98BDHWDmNeG3YD8Wf7ELG5m9kodJpRuYc5-cLLNaz35VWxu_iUq4PX2kU8PJcKfbpI7CrEXLYdpjBSkfR5qMs2GfD38gWHHDvNIMqPpbNKpqZ7-r8Zswqu48hP3pf96WX6K3dTXRSA3y7Pe9U-6rftCN4HdH7xePfNAz-vtBcYy4lAfm3_sK0JXfR1hbzS4gnAlWeIj1syFhXXYequcosgAW7hrnK2G2jg8rNO9P5BTnm-lrxWXL2SMiQiCGM1A0Ejtlg;.ASPXAUTH_TRUEHOME_RT=SWyzDI3vvnF8mTQP15KF4w8OPqoDbYS9cokRnDsVwuLBpOKsI8drh3oXZ0C6S9sp-O4lNp4tOITKLfKGnnf1fLbiB0NjCF5-DyvdW9nZMO7e-WLlO2PBjyA-E3OBZn-bkenaYqHpi0JyoGXGAfIt_PewCOkM7Ms4WA_3akXElVCdHt16QLR_Yifr3cXxFpVQwvg4XShDNfztLFcY1x91I3Jo2j-tEDAbUaWVjuD0T9Ui423_a73YxLKzESw1IIG9fpJDQlijTILjuJANzZC_ZrDLIzW-gpPyQH6O_j8GI65vwmudx7TQm1bj-mvIbKBgLmwtinCSbRtUoFAyTSA15cDcTyIOj34s24e_bbM35d6IHFQMFsZUhbfhOq2qc3pgN9Px9QCm8xjSTyQmoy-e98a8AAhnwJgZL9fwJJ0u8xBUhJel9Xv1WbdaAbOAxsPidMboq4AKrsHWl91tDCznCSRMdKOKe0xVy9qML6rHyi4zVxlF760iyOKlQIJLe-IchzH2yksG3NuUT6s9ov5AQSS1VZQ94QIaYr9ea4ES88wtwuPrDu59DjmUneRmG-z8rKtlMUjWljYe-v7l2j-aQIR5TTQFLkcD4rRnGxHMHnXpqFzoPYrzEMswFTe8XkeosG5KbnnvmcfqoDyQ-urYnZInAei7ZiJL-Wj5855c7iHcJ6fL6aTPxoAst52Az4DHlF-4-g;thlang=en-US;], timeout:10]
dev:24722023-09-02 04:58:54.794 PM infoH oneywell Thermo Downstairs TCC transaction: begin
dev:24712023-09-02 04:58:54.787 PM debug enable outside temps = No
dev:24712023-09-02 04:58:54.784 PM debug in get humid status enable humidity = No
dev:24712023-09-02 04:58:54.781 PM debug Adding cookie to collection: thlang=en-US
dev:24712023-09-02 04:58:54.778 PM debug Adding cookie to collection: .ASPXAUTH_TRUEHOME_RT=SWyzDI3vvnF8mTQP15KF4w8OPqoDbYS9cokRnDsVwuLBpOKsI8drh3oXZ0C6S9sp-O4lNp4tOITKLfKGnnf1fLbiB0NjCF5-DyvdW9nZMO7e-WLlO2PBjyA-E3OBZn-bkenaYqHpi0JyoGXGAfIt_PewCOkM7Ms4WA_3akXElVCdHt16QLR_Yifr3cXxFpVQwvg4XShDNfztLFcY1x91I3Jo2j-tEDAbUaWVjuD0T9Ui423_a73YxLKzESw1IIG9fpJDQlijTILjuJANzZC_ZrDLIzW-gpPyQH6O_j8GI65vwmudx7TQm1bj-mvIbKBgLmwtinCSbRtUoFAyTSA15cDcTyIOj34s24e_bbM35d6IHFQMFsZUhbfhOq2qc3pgN9Px9QCm8xjSTyQmoy-e98a8AAhnwJgZL9fwJJ0u8xBUhJel9Xv1WbdaAbOAxsPidMboq4AKrsHWl91tDCznCSRMdKOKe0xVy9qML6rHyi4zVxlF760iyOKlQIJLe-IchzH2yksG3NuUT6s9ov5AQSS1VZQ94QIaYr9ea4ES88wtwuPrDu59DjmUneRmG-z8rKtlMUjWljYe-v7l2j-aQIR5TTQFLkcD4rRnGxHMHnXpqFzoPYrzEMswFTe8XkeosG5KbnnvmcfqoDyQ-urYnZInAei7ZiJL-Wj5855c7iHcJ6fL6aTPxoAst52Az4DHlF-4-g
dev:24712023-09-02 04:58:54.773 PM debug Adding cookie to collection: .ASPXAUTH_TRUEHOME_AT=-AKfcKmPNT0e-uhsR7Yz_f3KiVyzexKFhAVUt8421nCsTQ2mbJJZilnG943rE92FRWUn1zN2rr2sOLam5jpV6K7QNvsspTNm1YYLneXJIbLzp5eORdOQBfUOTZsFsJIQ7Jb7XvkungpzNbJCTBe6wx0uGvlU-tjy7W2czNre0zRHRyBmzBQbmEC1qlQnMS5KBk0Z8FMRF5UZXuiLZaYjqk40kscY8sde9s-NW_s8TgQcUC2iR5hqC4iOA2CCkDyII6CoiZ9rHjFEXWpc7qE5jsGnkdAyXd9uGXVhvis-IrkCUGpEEvC8zm2YyuoOxxE4KB3931A3gRfgSmlrjoi97C02532eR-VdWCFGQrnisuHx2nwVPYRRhbDnptF5F6qfwc3TDyWtlB4HEtQBkyEjo-s3qZxWiQUMd1_LrGqDlj4MFvikDfubfOSmjbFRf7utz98BDHWDmNeG3YD8Wf7ELG5m9kodJpRuYc5-cLLNaz35VWxu_iUq4PX2kU8PJcKfbpI7CrEXLYdpjBSkfR5qMs2GfD38gWHHDvNIMqPpbNKpqZ7-r8Zswqu48hP3pf96WX6K3dTXRSA3y7Pe9U-6rftCN4HdH7xePfNAz-vtBcYy4lAfm3_sK0JXfR1hbzS4gnAlWeIj1syFhXXYequcosgAW7hrnK2G2jg8rNO9P5BTnm-lrxWXL2SMiQiCGM1A0Ejtlg
dev:24712023-09-02 04:58:54.768 PM debug Adding cookie to collection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
dev:24712023-09-02 04:58:54.764 PM debug Adding cookie to collection: ADRUM_BT1=R:0|i:197975|e:149
dev:24712023-09-02 04:58:54.761 PM debug Adding cookie to collection: SameSite=None
dev:24712023-09-02 04:58:54.758 PM debug Adding cookie to collection: ADRUM_BTa=R:0|g:cbfdbd78-6e91-4fb2-94dc-264e7d90e1f1|n:honeywell-prod_f7be1c76-506d-4111-81c5-fc62766aedb7
dev:24712023-09-02 04:58:54.756 PM debug Adding cookie to collection: ASP.NET_SessionId=3ijvpk1zmq4ucmaia0jqqbq2
dev:24712023-09-02 04:58:54.753 PM debug Request was successful, 302
dev:24712023-09-02 04:58:54.287 PM debug Honeywell TCC 'login'
Note that there are 8 cookies in both our logs and that's correct. However, the next step is to send a getStatus request. This is where it goes off the rails for you. You're basically getting a "not found" or "invalid" type of response.
Also, are you using the Parent/Child version of this Driver or the single?
Okay, let's go in parts!
I'm located in Panama, and I have to use US settings, which is where I buy my equipment. To adjust this URL, which part should I test?
I don't use Child, I've created a virtual drive and linked it directly to Total Confort. Should I try something different?
Thank you.
