Honeywell T6Pro
Honeywell T6Pro will not include, has been factory reset.
Don't have much information to go on here.. But to be sure, this only works for the Z-Wave model..
  • Standard programmable: TH6210U, TH6220U, TH6320U
  • T6 Pro Smart Wi-Fi: TH6220WF, TH6320WF
  • T6 Pro Z-Wave: TH6320ZW
  • T6 Pro Hydronic: TH6100AF
So for the Z-Wave model.. Are you using these instructions:
  • Start Inclusion or Exclusion on your hub
  • On a TH6320ZW2003, open thermostat Menu → Z-Wave Setup → Select. It detects its state: excluded thermostat starts inclusion; included thermostat starts exclusion. Tap Select again after the controller is listening.
  • Successful inclusion shows INCLUDED, a node ID, and the solid Z-Wave icon. For exclusion, verify Menu → Device Info shows node ID 000.
  • On the newer TH6320ZW2007, it enters SmartStart inclusion automatically after power-up and system configuration. Without SmartStart, use Menu → Z-Wave Setup → Start Including.
Thank you. I was able to get it connected, unable to update firmware, though.
I've never seen Honeywell send out a firmware update, though I think one is available for the 700 series z-wave unit.
