I have one of these devices that was on an old zwave network. I factory-reset it via 3-quick taps first on the top and then on the bottom paddles, and Hubitat then found it via Inclusion. It created this device:
My problem is that I don't seem to be able to control it via any of these buttons nor via a test basic app:
Note the Bedroom Fan device in the Basic Rule doesn't even present the 3 possible speeds to choose.
What am I missing?
I'm also now seeing this error crop up in the logs:
dev:36 2023-06-15 05:19:14.011 PMerror org.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: geFanController.push() is applicable for argument types: (java.math.BigDecimal) values: [2]
Possible solutions: use([Ljava.lang.Object;), run(), run(), dump(), parse(java.lang.String), is(java.lang.Object) (method push)
Hello, did you try hitting "configure" on that device page? You shouldn't have to (it does it upon pairing) but it wouldn't hurt to try.
What does your Z-wave details page (Settings, Z-wave Details) look like? Can you post a screenshot of that page?
Is this a C7, C8, C5, or which hub?
Yes I've ht Configure but it does not appear to do anything.
This is a C7 hub - does that make a difference compared to a C8?
Here is my Zwave page:
system
Closed
June 15, 2024, 10:52pm
5
