I am having the same issue as this post which is closed.
When adding the switch it mistakes it as a Ring Retrofit Alarm and creates 8 contacts. I cannot delete the contacts after successfully configuring the switch. Any thoughts? Thanks.
On the device page change the driver (type) to the generic driver named "Device" and save.
Press the "delete all childs" command button.
Switch back to the correct driver and save again.
