I need some help with the Homeseer;ight sensor.
I have a rule where it the light on my dryer goes out and stays. Turn off virtual dryer contact/switch.
In the Alexa app.. when virtual dryer contact closes announce :dryer finished."
I use VIRTUAL CONTACT WITH SWITCH for virtual dryer.
I have the same issue as well. i spent many hours trying to fix this. it seems like now the sensor will only turn on and off when it senses light it does not stay on. i would love a fix for this.
It started working again and stopped today. I have a feeling room light is being seen. I will try recovering the sensor so it only seems the dryer timer light.
After reading that you may have issues with lights. i decided to put the sensor on a different light. The original light was a green light with words that went on and off with the dryer i put it on a blue light and it works. The only thing that is not good it is on the power button so i taped it on with fabric sports tape and some duct tape and its working and no light goes through as i used a flash light to try to trigger it. good luck on your journey lol
That’s a screenshot of the log for your sensor device.
The rule itself can also create log entries, but you have to enable that in the rule’s configuration page.
ETA: If the logs for the device suggest that the sensor is turning on/off when it shouldn’t, then that would be the first thing to troubleshoot. If not, then the log entries for the rule are the next place to look.
