Homeseer Leak Sensor behaving oddly
So I have several of the HS-LS100+ sensors. I had one that needed a battery replacement the other day and I did so. After that it was no longer responding or it seemed that way. I ended up removing it and readding it to the hub. It did exclusion and pairing with zero issues. I sent a configuration command to it and it appeared to process it just fine so it put it back where it goes. But it hasn't reported in since that time. If I send more commands it gives the old "will send when the device wakes up message". It seems partially dead with respect to reporting but since it will exclude and include it's not totally dead. Any other ideas or should I just replace the darn thing?
