Homeseer HS-FL1000+ Toggling On Zwave control
Hey All,
Appreciate your time!
I have a Homeseer HS-FL1000+ installed and am having issues with the light toggling.
Here's a log:
07:41:38.555 pm infoShop Motion was turned off
07:41:38.550 pm debugBasic Report - Value: 0
07:41:38.546 pm debugparse:zw device: xx, command: 2003, payload: 00 , isMulticast: false
07:41:38.495 pm infoShop Motion motion became inactive
07:41:38.491 pm debugNotification - Type: Home Security, Event: 0, EventParameters: [8]
07:41:38.487 pm debugparse:zw device: xx, command: 7105, payload: 00 00 00 FF 07 00 01 08 , isMulticast: false
07:41:36.837 pm infoShop Motion was turned on
07:41:36.833 pm debugBasic Report - Value: 255
07:41:36.829 pm debugparse:zw device: xx, command: 2003, payload: FF , isMulticast: false
07:41:36.745 pm infoShop Motion was turned on
07:41:36.741 pm debugSwitch Binary Report - Value: 255
07:41:36.737 pm debugparse:zw device: xx, command: 2503, payload: FF , isMulticast: false
07:41:34.905 pm infoShop Motion was turned on
07:41:34.901 pm debugBasic Report - Value: 255
07:41:34.897 pm debugparse:zw device: xx, command: 2003, payload: FF , isMulticast: false
07:41:34.022 pm debugon()
07:41:33.930 pm infoShop Motion motion became active
07:41:33.926 pm debugNotification - Type: Home Security, Event: 8, EventParameters: []
07:41:33.922 pm debugparse:zw device: xx, command: 7105, payload: 00 00 00 FF 07 08 00 , isMulticast: false
07:41:33.698 pm infoShop Motion was turned off
07:41:33.693 pm debugBasic Report - Value: 0
07:41:33.689 pm debugparse:zw device: xx, command: 2003, payload: 00 , isMulticast: false
07:41:33.535 pm infoShop Motion motion became inactive
07:41:33.531 pm debugNotification - Type: Home Security, Event: 0, EventParameters: [8]
07:41:33.527 pm debugparse:zw device: xx, command: 7105, payload: 00 00 00 FF 07 00 01 08 , isMulticast: false
07:41:30.909 pm infoShop Motion was turned on
07:41:30.905 pm debugSwitch Binary Report - Value: 255
07:41:30.901 pm debugparse:zw device: xx, command: 2503, payload: FF , isMulticast: false
07:41:29.353 pm infoShop Motion was turned on
07:41:29.348 pm debugBasic Report - Value: 255
07:41:29.344 pm debugparse:zw device: xx, command: 2003, payload: FF , isMulticast: false
07:41:28.995 pm debugon()
07:41:28.877 pm infoShop Motion motion became active
07:41:28.873 pm debugNotification - Type: Home Security, Eve
You can see that it is cycling extremely rapid.
The settings are PIR Trigger off 5 minutes
Lux Thresh : Always don't turn light on
Sensor Report Interval: 10 min
Flood light control: Z-wave only
Floodlight control by lux: Control by lux and PIR
PIR Sensitivity: Low
I am integrating into HA and using it to control the light through motion currently and it is doing what's displayed in the log above.
It does the same thing when it is in native HE control with PIR only.
No matter what settings are in HE it will toggle unless I turn it on by lux and leave it on.
The dials are set to the settings as shown in the documentation. Light is to test and dusk to dawn is to sun.
"08:11:37.036 pm infoShop Motion was turned off
08:11:31.935 pm infoShop Motion was turned off
08:11:16.673 pm infoShop Motion: Temperature report received: 22.7°F
08:11:16.663 pm infoShop Motion Illuminance report: 26Lux
08:06:41.925 pm infoShop Motion was turned on
08:06:39.593 pm infoShop Motion was turned off
08:06:39.537 pm infoShop Motion motion became inactive
08:06:36.921 pm infoShop Motion was turned on
08:06:34.854 pm infoShop Motion was turned on
08:06:34.760 pm infoShop Motion motion became active
08:06:34.585 pm infoShop Motion was turned off
08:06:34.526 pm infoShop Motion motion became inactive
08:06:31.622 pm infoShop Motion was turned on
08:06:29.700 pm infoShop Motion was turned on
08:06:29.613 pm infoShop Motion motion became active"
Appears to be working but still getting weird log values. I had to setup a rule to only turn on after dusk. I have a 5 second motion delay and then a 5 minute on time before exiting and turning switch off.
If you notice the motion state turns active and the comman to turn on is less that .1 secons after active. It has multiple on commands that do not line up with a 5 second delay and one that is close enough to say it does. You can see there are multiple on off toggles as well despite it staying on for 5 minutes by visually watching it..... not sure whats up with this behavior
Last log captures it really well... the light is turning itself on and seems to be re-enabling the rule...
08:27:22.020 pm infoShop Motion was turned off
08:27:20.834 pm infoShop Motion was turned off
08:27:20.794 pm infoShop Motion was turned on
08:27:19.274 pm infoShop Motion was turned off
08:27:17.986 pm infoShop Motion was turned off
08:27:14.525 pm infoShop Motion motion became inactive
08:27:08.600 pm infoShop Motion was turned on
08:27:06.376 pm infoShop Motion was turned on
08:27:06.212 pm infoShop Motion motion became active
08:27:05.971 pm infoShop Motion was turned off
08:27:05.810 pm infoShop Motion motion became inactive
08:27:05.132 pm infoShop Motion was turned on
08:27:04.763 pm infoShop Motion was turned on
08:27:04.437 pm infoShop Motion was turned on
08:27:04.060 pm infoShop Motion was turned on
08:27:01.536 pm infoShop Motion was turned on
08:27:01.201 pm infoShop Motion motion became active
08:27:00.961 pm infoShop Motion was turned off
08:27:00.802 pm infoShop Motion motion became inactive
08:26:58.571 pm infoShop Motion was turned on
08:26:56.322 pm infoShop Motion was turned on
08:26:56.154 pm infoShop Motion motion became active
08:26:55.941 pm infoShop Motion was turned off
08:26:55.779 pm infoShop Motion motion became inactive
08:26:53.552 pm infoShop Motion was turned on
08:26:51.313 pm infoShop Motion was turned on
08:26:51.147 pm infoShop Motion motion became active
08:26:50.924 pm infoShop Motion was turned off
08:26:50.761 pm infoShop Motion motion became inactive
08:26:48.536 pm infoShop Motion was turned on
08:26:46.295 pm infoShop Motion was turned on
08:26:46.130 pm infoShop Motion motion became active
08:26:45.911 pm infoShop Motion was turned off
08:26:45.749 pm infoShop Motion motion became inactive
08:26:43.122 pm infoShop Motion was turned on
08:26:41.601 pm infoShop Motion was turned on
08:26:41.123 pm infoShop Motion motion became active
08:26:40.891 pm infoShop Motion was turned off
08:26:40.727 pm infoShop Motion motion became inactive
08:26:38.501 pm infoShop Motion was turned on
08:26:36.250 pm infoShop Motion was turned on
08:26:36.084 pm infoShop Motion motion became active
08:26:35.931 pm infoShop Motion was turned off
08:26:35.710 pm infoShop Motion motion became inactive
08:26:33.486 pm infoShop Motion was turned on
08:26:31.233 pm infoShop Motion was turned on
08:26:31.069 pm infoShop Motion motion became active
08:26:30.855 pm infoShop Motion was turned off
08:26:30.694 pm infoShop Motion motion became inactive
08:26:28.566 pm infoShop Motion was turned on
08:26:26.223 pm infoShop Motion was turned on
08:26:26.061 pm infoShop Motion motion became active
08:26:25.845 pm infoShop Motion was turned off
08:26:25.682 pm infoShop Motion motion became inactive
08:26:23.257 pm infoShop Motion was turned on
08:26:21.410 pm infoShop Motion was turned on
08:26:21.266 pm infoShop Motion motion became active
