HomePod does not respond when used for TTS
As the subject says. Since I updated to 2.3.9.181 there's no response from a HomePod used as a TTS device. The logs don't show any error and appear to be OK. But no speech from the device. I tried restarting the integration, but no change.
Unlike others have reported, HomeKit integration for me seems to be working OK. Hubitat devices show up in Home and can be controlled there. It's just the TTS that stopped working.
It's not a critical function for me as I also have notifications sent to my phone. But it is really helpful and I'd like to have it back.
Under airplay integration did you click check devices and reinstall dependencies and see how that goes.
Tried that. It didn't make any difference.
OK. I realized that reinstall dependencies created new devices. The new devices do work. Unfortunately airplay devices are apparently not available in Swap Apps Device. I guess I'll need to update all of the rules where the old device is used to use the new device. Blech. But at least it's working.
Likely the ip's changed and mDNS wasn't picking them up. I would set DHCP reservations in your router (or what ever provides DHCP on your network) for each homepod or apple tv as well as for the hub itself.
Thought I had, but apparently something "helpfully" unreserved them. (I'm looking at you Comcast.) The hub was unreserved also, so I'm glad I checked.
Thanks for your help!
I just went through this with 2 business clients. Comcast wiped their modems to default. So they have their own firewalls but now the comcast stuff was natting as well instead of bridge mode, outputting DHCP and wifi... was annoying. Get FIOS if you can...
