HomeKit issues
So a brand new C8 hub, seemed to ve very sluggish and non-responsive when I originally set it up, but it came out of it after a couple of reboots.
I did the HomeKit integration, worked ok for a bit, but now it has just completely gone dead for hours on end, I have to restart the C8 hub to get it working again and then it only stays for a little time and goes offline again.
Tried to check the integration, and turn on the option to restart hourly and it just hangs at the integration screen like it is loading.
Opted to uninstall it entirely, thinking a fresh install may help, and now I can't even install it any longer, I just get an HTTP-500 error and the app won't load at all.
Hub version is: 2.5.1.174
Anyone have any ideas? It seemed fine at first but then just tanked. This is a hub at our cabin, my home one is working just fine on the same code base with about 60-70 devices.
This one has literally 3 devices.
You could reboot and check the box to rebuild the database, and if that doesn't help, I would do a soft reset. If that doesn't work, you can try a hard reset, which shouldn't be an issue with only three device to re-pair.
If none of that fixes it, you may want to think about a warranty claim.
Same issue here. I've been using the HomeKit Bridge integration for years and over the past 2 days or so I've had significant issues with devices not responding. Restarting the integration or rebooting the hub (C-8 Pro on 2.5.1.174) works temporarily. I'm wondering if it's an issue with the latest software version.
I was also seeing HomeKit hangs after a recent update, but disabling hourly reboot fixed it for me.
The connection depends on how the mDNS/Bonjour is processed over the home network. Different routers act differently, and any network change (like a silent router software update) may affect it.
That's the first thing to try, yes. It's been disabled for the new integration installs by default for a while.
Any details on the requirements needed for mDNS/Bounjour? I don't have hourly reboot turned on or mDNS/Bonjour restart turned on in network settings.
I haven't changed any settings, but I do see that my Ubiquiti UniFi gateway had an update right around when this started happening and there's a comment in the release notes about remote mDNS "fixes". Possibly a red herring, but this may be the root of the issue.
Coincidentally, I noticed in the integration, there are "no active connections" when things aren't working. Is there a way to specify the Homekit hub with a static IP?
So it acted like it went away, but now it is back again.
Essentially the homekit app just goes dead. (See photo) when you try to open the integration on the hub itself, then the entire hub goes to pot.
I either have to reboot the hub forcefully to kill the circle of death, once I do homekit integration comes back online but it ends up failing sooner or later and I have to do it all again.
I am also getting the second error when I try to make any rules, something isn't right with my system, never run into anything like this before, so it is all new to me
Can you PM me the hub id? I'll check the engineering logs.
Sent, thanks!
Just popping back in to see if you found anything in the engineering logs?
I have removed the integration entirely as the hub was just going unresponsive and my automations on the HomeKit side were failing when the devices became unreachable
I think I got something. Will have to do a build with the fix, it should be out next week.
Hello, just following up here, I’ve had the same issue
