HomeKit Controller Integration never discovers a device on a separate VLAN, despite working mDNS reflection
Hub: C-8 Pro running 2.5.1.183
Setup:
  • UniFi UDM SE, three VLANs: Main, IoT, Guest
  • Hubitat sits on Main (192.168.11.x)
  • Device in question (Aqara FP2 presence sensor) sits on IoT (192.168.12.x)
  • Gateway mDNS Proxy set to Custom, VLAN Scope includes both Main and IoT, Service Scope set to All
What I'm trying to do: pair the FP2 to Hubitat via HomeKit Controller Integration. It's a standalone Wi-Fi HAP accessory, no Aqara hub involved.
What I've tried, in order:
  1. Standard pairing flow β€” HomeKit Controller Integration never lists it, "No orphaned HomeKit pairings found" every time.
  2. Removed and re-added the FP2 in the Aqara app (Android), confirmed live on the network via UniFi's client list the whole time.
  3. Power-cycled the FP2 immediately before scanning, per advice from an older thread on this exact device β€” no change.
  4. Fully removed the HomeKit Controller Integration app and recreated it from scratch β€” same result.
  5. Full hub reboot β€” same result.
  6. As a control: paired the FP2 directly to real Apple Home from an iPhone on the Main VLAN. This worked immediately, no issues, confirming the mDNS reflector is functioning for at least one client type across this VLAN boundary.
  7. As a second control: tried Home Assistant's HomeKit Device integration (HA also sits on Main). It also never discovers the FP2, same symptom.
So: a real Apple client crosses the VLAN fine via the reflector, but two independent third-party HAP-controller implementations (Hubitat's and Home Assistant's aiohomekit-based one) both fail to discover the same device across the identical boundary, with an apparently-correct mDNS proxy config on the gateway side.
Has anyone hit this specific pattern? Wondering if there's something about how Hubitat's mDNS browse is scoped (bound to a single interface, ignoring reflected/rewritten packets, etc.) that differs from how Apple's own Bonjour stack handles a reflected multicast response. Not looking to flatten my VLANs to fix this β€” trying to understand whether it's a known limitation before I go further.
Happy to grab logs/debug output if someone can point me at how to get HomeKit Controller Integration to actually log its scan activity β€” right now it produces no log output at all during a scan attempt.
FWIW: I don't know anything about Aqara. I know a little about Unifi, a bit more about HomeKit, and a lot about mDNS.
The most likely thing is that the mDNS information is being bridged incorrectly. Last I knew, Unifi was using Avahi under the covers, which does not function correctly in a number of scenarios.
The two largest issues are forwarding of link-local addresses which are invalid anywhere outside of the local LAN segment they are created in, and corrupt NSEC (negative answer) records. HomeKit uses a lot of both of these.
The easiest way to work this is to move your HomeKit controller to the IoT LAN, or your Aqara to the Main LAN. If you are dead set on having them in different LANs, you will need to start getting very creative. My advice is to not go down this path... :face_with_head_bandage:
I couldn't get the HomeKit Controller Integration to work even with the devices on the same subnet with the hub setting the devices on mDNS.
I've concluded that the integration is garbage. I tried everything I know to make it work and just gave up.
