Homekit Accessory Not Found
Hi OgieWon
Thanks for joining the discussion. I download the reference BonJour Browser on the Mac. Also installed the mDNS tool (cheap) and run them.
Not sure what I do with the info - Here are the Hubitat entries for mDNS (also Available PDF with more data. I don't see how to upload a PDF to this site.)
  • List item
Domain:local.
Service:_http._tcp.
IPv4 192.168.0.55:80
Domain:local.
Service:_hap._tcp.
IPv4 192.168.0.55:21063
ci:2
s#:1
ff:0
c#:1
sf:1
sh:l2OW2Q==
pv:1.1
md:C-8
Domain:local.
Service:_hubitat._tcp.
hubMeshEnabled:false
platformVersion:2.3.6.146
hubMeshProtocol:1.0
IPv4:192.168.0.55
hubUID:a1300418-92b6-4101-8a80-77f31ad5299b
hubVersion:C-8
Domain:local.
Service:_ltpdu._udp.
Names:
Nanoleaf A19 C55-F53A
Nanoleaf A19 C9D-4794
Domain:local.
Name:Nanoleaf A19 C55-F53A
IPv6 fd00:3849:cef3:0:9d33:dee9:ad1a:64de:5653
srcvers:3.5.41
md:NL67
xp:4227471BBA9A4078
eui64:F082C0FFFE4CBDF8
Domain:local.
Service:_meshcop._udp.
Names:
Apple BorderRouter #8A50
Apple BorderRouter #D496
Apple BorderRouter #8310
Domain:local.
Name:Apple BorderRouter #8A50
IPv4 192.168.0.81:49154
IPv6 fd27:471b:ba9a:4078:47a:e130:f5e9:9ffe:49154
IPv6 fe80::ca:753b:5129:dd40%en1:49154
IPv6 fd27:471b:ba9a:4078:2:fdcc:f84e:44a5:49154
tv:1.3.0
vn:Apple Inc.
mn:BorderRouter
rv:1
nn:MyHome13
omain:local.
Service:_matter._tcp.
Names:
5486F0E08397808D-0000000082B83C52
BB78BDC43E1F405F-0000000088774AAC
5486F0E08397808D-00000000D794C821
BB78BDC43E1F405F-000000004BABAA02
5486F0E08397808D-00000000A490E1C0
B40093703FFD844E-015A23E806EA5CC1
B40093703FFD844E-015A20EEB3EF37E1
Domain:local.
IPv4 192.168.0.122:53771
IPv6 fe80::85:6be7:cfa1:5a7%en1:53771
IPv6 fd27:471b:ba9a:4078:8bb:89c1:5294:effa:53771
IPv6 fd27:471b:ba9a:4078:2:fd00:3849:cef3:53771
T:1
I have not mentioned, but Sonos also on the WiFi network:
Domain:local.
Service:_sonos._tcp.
Names:
Sonos-542A1BD64A10@Living Room
Sonos-949F3E8F8E94@Living Room
Sonos-542A1B22EBF8@Sub
Sonos-48A6B88F9FC8@Den
Sonos-949F3EFFEA08@Living Room
Sonos-48A6B8457D29@Bedroom
Sonos-F0F6C1049528@Sub Mini
Sonos-542A1B4835DC@Roam
LOL - I am right there with you! :wink:
Hopefully, @jtp10181 will be able to glean some info from the data your shared.
One more question, what type of ISP connection are you using? Does your ISP-provided hardware also act as a router, in addition to your personal TP-Link router? Double NAT scenarios can cause some strange behaviors.
I just wanted to see if the Hub was broadcasting the hap info. I dont know a whole more besides that needs to be there for HK to be able to pair with it.
Somewhere not long ago a user posted a CURL command you could issue against the hub HK integration to see what kind of data it spit back out, if someone can find that, might be worth a look.
MySpectrum ISP modem shows a standard IP address (no obvious NAT) to the TP-link router. So the only NAT that I can determine is with the TP-Link.
Is there anyone at Hubitat to contact about this? They were getting good reviews 8 months ago on YouTube channels. I know y'all are doing what ya can.
Thanks again
@gopher.ny is the Hubitat engineer that supports the Apple HomeKit integration, if I recall correctly. I'd recommend you try reaching out to him directly.
Thanks ogiewon - I will do just that.
I sent a message to Gopher.NY. FYI
Is the setting for "relaxed security" at the bottom of HomeKit integration gone now for C8 and version 2.3.7.143? I don't see it on mine. I was able to successfully connect Hubitat into HomeKit with a few devices connected. But after I tried to add more devices, they will not show up in HomeKit.
Do you have all devices on iOS 17 and the updated Home architecture?
I updated my phone to iOS 17 but no luck, I didn't want to update the Home architecture because it says that it won't be compatible with my work Macbook (and IT won't let me upgrade that yet). In the HomeKit app of Hubitat, I then clicked "Unpair controllers", removed the bridge, reset the integration, and now it found all the devices. I just hope when I add a new one in the future it will see it. Thank you!
So far people with issues like that said it was resolved by going to the new architecture, not sure why, it should work either way.
