So I need help. I don't think its Hubitat (support has been great), but rather Homebridge. It's not home bridge per se but rather how I have it setup I suppose.
I have Homebridge running on a Synology Diskstation 918+ using the oznu/homebridge GUI docker container. This thing is great and made the docker installation process and editing the config.json file seamless.
Below is my config.json including and excluding many items (with nest and mpeg plugin configs redacted for privacy)
"bridge": {
"name": "Homebridge",
"username": "0E:09:ddd:55:C9:47",
"port": 51821,
"pin": "585-xx-087"
"platforms": [
"name": "Config",
"port": 8080,
"auth": "form",
"theme": "blue",
"tempUnits": "c",
"log": {
"method": "file",
"path": "/"
"platform": "config"
"platform": "Hubitat",
"name": "Hubitat",
"app_url": "http://xxxx/apps/api/1479/",
"polling_seconds": 10,
"update_method": "direct",
"access_token": "8237xxxxxb4c27d6",
"excluded_capabilities": {
"9": [
"RelativeHumidityMeasurement",
"TemperatureMeasurement"
"36": [
"37": [
"38": [
"40": [
"41": [
"42": [
"45": [
"132": [
"257": [
"IlluminanceMeasurement",
"MotionSensor",
"Sensor",
"454": [
"897": [
"898": [
"1025": [
"1441": [
"MotionSensor",
"Sensor"
"1442": [
"MotionSensor",
"Sensor"
"1443": [
"MotionSensor",
"Sensor"
"1444": [
"MotionSensor",
"Sensor"
"1445": [
"MotionSensor",
"Sensor"
"1827": [
"ContactSensor",
"Sensor"
"1857": [
"MotionSensor",
"Sensor"
"1858": [
"MotionSensor",
"Sensor"
"1859": [
"MotionSensor",
"Sensor"
"1860": [
"MotionSensor",
"Sensor"
"platform": "Roomba",
"name": "Roomba",
"robots": [
"name": "Downstairs Vacuum",
"blid": "xxx",
"password": ":1:xxxx:TowyTGROMO3I8XuN",
"address": "192.168.7.xxx"
"accessories": []
I have 83 devices on the homebridge altogether (I have a lot of lights and doors) and I removed many capabilities to avoid having dozens of unwanted temperature sensors.
To save the effort of listing every device connected with the HE hub through Homebridge they are mostly GE Z-Wave Switches/Dimemrs and Iris contacts and Motion sensors.
I have a virtual switch for goodnight which turns the entire house off and I have my intermatic pool device. I also have a netatmo device to measure outdoor temperature.
The issue seems to be that whenever homebridge runs, my hub slows to a crawl until the point that it crashes.
Please tell me how I can help fix the issue as I believe this issue is a bit singular to me and my setup as many of you do not seem to have issues with homebridge.
__
