I have an issue where HSM is accepting modification to motion detector selections in the config page, reflecting that on HSM top page - but still including those de-selected motion sensors once armed. any tips why when i set "Intrusion Home" active - and that configuration does NOT include group "Patio-Zone" - that after arming - the alarm triggers from Patio Zone?
Screenshots below:
This is the zone group Patio with three motion controllers:
This is patio zone showing no enrollment in anything other than HSM:
This is HSM showing that Intrusion AWAY does have the motion patio zone, and that Intrusion HOME does not -
WOW - that was fast - thanks SO MUCH - and exactly why i recommend hubitat!
I would have bet you money - but it sure appears this is me w a user error of not pressing both "Done's"...
I just hit done with and done with HSM per pics below... set alarm in Intruder HOME - walked around to patio - and DID NOT setoff the HOME intruder alarm.. Sorry to bother you with this easy one, really thought i had it triple checked!
If you have a second can you direct me to any answer on how i can see if HSM/Hubitat is armed or disarmed from the phone app (maybe in tiles?) or how to arm/disarm remotely? I have been searching support and havent given up yet..
Thanks again including my pics on this "mistake / fix" just in case it helps others avoid my mistakes...
awesome! and trick for newbies - when adding this tile - don't select anything in "pick a device" - just go straight to the second column, "Pick a template" - then once the tile is added - you click the tile and see many options for arm / disarm.
pretty cool!
