Sadly, that isn't an option. All of the camera events get sent to the hub.
Would love to hear more about Blue Iris integration into Hubitat. I'll search for it as well. Thanks for the nudge!
Yeah ok didn't realise that what about the email option in the hikvision config? Could you somehow make that work even with pushover maybe?
Thanks for chiming in. I realize there are other options but this one should be the quickest/least complex and could be useful by others with these cameras. I believe this is a recent addition to the camera firmware that many may not be aware of.
Originally I had hoped that I could send http requests from the camera to Maker API but that isn't the case.
I have amcrest cameras and pair with this software to turn a email into a http hit to hubitat
This might work for your use case?
Thanks for this. I'm a long time tinycam user and will check it out - didn't even realize there was a windows version until now.
Thanks for the suggestions. I was hoping to "cut out the middle man" by notifying the hub directly, however. It seems within grasp (the hub is receiving these events) but I lack the experience/chops to seal the deal.
My backup plan was to wire ecolink z-wave dry contact sensors directly to the cameras in order to avoid having to run additional computers/email servers etc but I'll still have to weigh the options.
Looks good. Is it quick?
Typically from the time I have motion in front of the camera to the virtual motion sensor triggering is < 1s. I'm surprised at how fast it actually is. I suppose it may vary by camera, but mine are fast.
Spun up a linux vm and it works great. Seems like the best option for me at the moment. Thanks.
Cheers! Glad it worked for you!
A lot of the newer cameras don't have the wired alarm output, so I'm interested in getting the "HTTP Data Transmission" working. @Mr_B: What was your setup to receive the HTTP transmissions in your first post?
To boil it down, Hikvision DS-2CD2555FWD-IS with "HTTP Data Transmission" enabled can send encoded xml events to the app port (39501) on the Hubitat hub. That's as far as I got.
Blue iris?
This will integrate wonderfully with any compatible ip cam and hubitat.
I just moved over to Blue Iris a few weeks ago. It's amazingly flexible. Getting cameras to trigger hubitat automations and vis versa is easy. Plus it can do so much more. I was using iVMS before which worked good but limited.
@Mr_B: I took a stab at it and got HTTP Data Streaming to work. I'm a HW engineer, so my coding skills are very limited and date back more than a couple of decades. Give me a few days to flush out the code, add some features, learn how to setup a repository on github and I will share it.
@Mr_B: Just released the code here: [RELEASE] Hikvision Alarm (HTTP Listening/Data Streaming)
I hope this is useful for your needs!
Awesome. Will try it out.
