I am looking to control (dim only) about 200ft of 2835 led strip (understand will want to inject power at several points). What I am here to ask about is the controller to handle it.
By my calc this is 3360 LEDs, 24v, 0.2w/led=28 amp
Looking for suggestions on cheapest controller for this that will work in hubitat. 1 channel is obviously best (or multi channel is fine as long as 1 channel can handle 28amp) is this way outside of normal? Or should I be looking to group multiple controllers together in hubitat, and split my run up into 5? segments or what?
Yeah I have both of those for other stuff. Maybe I am overthinking this. There are kits on amazon with 3000 leds somehow pulling like 24w.... they must just be under powering them like crazy or something.
RGBGenie has a single channel that can do 8A 12-36V, still not really in the neighborhood of what you're talking about. I'm thinking using a normal single channel LED controller to toggle a relay is the best bet here, probably need a 40A DC rated relay, automotive is probably the cheapest source. You won't have pwm (dimming) but it'll work.
