Hi im curently in the philipines what hub should i buy
We use the us outlet but on 220 should i buy the one for us or for the uk
Welcome to the community.
The latest hubs use a USB cable to power the hub I believe.
The hub doesn't care what voltage your mains powered devices will be using.
What does matter is the z-wave radio frequency that is used in your country.
You need to buy a hub that has a z-wave stick that is compatible.
It would appear from this
" so this means the Philippines uses EU zwave frequency"
that the philpines uses the same frequency as the EU so I would suggest that is what you order fro the Hubitat site.
DO CHECK FIRST THOUGH.
Thanks in the philipines thay use 868.4 frequency
When you go to the Hubitat website you with see the options for which hub to buy.
