Hestia™ A New Smart Home Dashboard for Hubitat
Hi my public ip comes back the same after a router reboot. Update I had to wait an hour before restarting my router but it did change the Ip and Hestia is now working as should be including cloud connection. Thank you
Nope.
Thank you both, glad to hear this is resolved and apologies once again. It's only an issue while working towards the transition to a safer framework that removes vulnerabilities that we identified in a previous scan.
Working towards creating native Android and macOS apps next.
Just want to let you know the good as well as the bad you have this dashboard rocking now thank you for all your hard work on this, its an excellent dashboard worth the effort.
Fixed and working :slightly_smiling_face:
All was working perfect then all came up with
Cloud Sync
Reachability of the hestari.com backend
This device can read the record for this network, but the last save did not land: backend rejected the write (HTTP 500).
Reading, but not writing
this is what AI says on the error.
An HTTP 500 error means your device is communicating fine with the network, but the hestari.com backend server encountered an internal error when it tried to process and save your data. Because the backend crashed during the write operation, it rejected the update, leaving your device in a "read-only" state for this specific sync cycle.
That one was not your setup. The backend keeps settings in Cloudflare's key-value store, and the daily write allowance there is shared across every household rather than being per-home. It ran out, so writes started failing for everyone at once while reads carried on working. That is exactly why it showed up as "reading, but not writing".
Two things have changed since. The plan is upgraded so the daily cap is gone, and the backend now only rewrites values that actually changed rather than on every single save, which cut the write volume by about two thirds.
Nothing for you to do. It should be writing again already. If Cloud Sync shows anything other than green after a reload, tell me.
And thank you for the kind words. You found three real problems this week and the dashboard is better for every one of them.
