Help Zooz Switch ZEN24 no refreshing
This was working fine, but now it does not auto update when I turn the switch on or off in the HUB, the response time it's almost immediately. Also when I try to turn the light on from the dashboard all its says Sending but the lights do turn on and off.
Are you using the new Zooz Central Scene Dimmer driver?
What firmware does it show in the data section?
Yes im using Zooz Central Scene Dimmer, not sure if its the old or new, Their is only one to choose.
Where is the Data section ?
Sorry here is the data info
I think its was working ok before the latest update not sure if its relevant
It looks like you're not using the central scene functionality so as a temporary solution change it to the generic z-wave dimmer driver.
I'm not sure if that will report correctly either, but it's worth trying.
After changing to that generic driver, make sure you don't save the settings or press configure because it will change the device's auto on/off configuration parameters.
Ask @agnes.zooz or send an e-mail to zooz, but I suspect your Zen24 might need a firmware update to support the Zooz central scene dimmer driver. Did you manually select the Zooz driver, or did the hub select it for you?
S.
The Hub select it automatically. I might ask zooz support and see what they said.
I just change it to Generic central dimmer and it works like it did before. I will have to wait for an update because i dont have a zwave stick.
Thank you
Just make sure you don't save the settings or click configure because that can cause the device to start turning on and/or off automatically.
Will do, Thank you very much
Hello, just an update everything is working like before
the Zooz Central Scene Dimmer driver is working with my device and the problems I was experiencing was caused by the lifeline group not being associated. @krlaframboise was super helpful in helping me figure out what the problem was.
