April,
I was just asking as my door unlock (like me using Hubitat) is rather new. I only set the unlock up 4 days ago. I initially tried it with using the iPhone and found that sometimes the location of the phone would be just outside the defined presence area. Once I opened the Hubitat app, it then moved inward to my current location. So I swapped to the SmartThings Arrival Sensor and it's been accurate both in testing and regular use. I may open up the defined area in the Hubitat app and use an AND statement requiring both the iPhone and the Arrival sensor presence to trigger the unlock event since I normally carry both the phone and my keys which has the Arrival sensor on them.
Bill
The error you see in post 20 isn't really a concern; it just means you're running "Cancel Delayed Actions" when there isn't any currently-delayed action to cancel. (I'm not sure whether staff considers the throwing of this error a bug.)
I'm not sure why your rule wouldn't be working. My guess is that the Private Boolean on Rule 1 isn't getting set back to False, which could happen if your presence sensor went away and came back (without your knowledge), which would restart those 5 minutes. Turn on at least trigger and actions logging for this rule and see if that's the case. I'd do that for Rule 2 as well so you can verify its execution path.
Just wanted to follow up and let you know the rule is working correctly. Thanks again for your help
No problem. Glad to hear that it's working well!
