Made some changes for you, please try this version:
* gmcmap.com Geiger Counter Query
import groovy.json.JsonSlurper
metadata {
definition(name: "gmcmap.com Geiger Counter", namespace: "staze", author: "Ryan Stasel", importUrl: "https://raw.githubusercontent.com/staze/hubitat-gmcmap/master/hubitat-gmcmap.groovy") {
capability "Sensor"
capability "Polling"
attribute "CPM", "NUMBER"
attribute "ACPM", "NUMBER"
attribute "uSv", "NUMBER"
preferences {
section("URIs") {
input "GeigerID", "text", title: "Geiger ID", required: true
input "Timezone", "text", title: "Timezone", required: false
input name: 'updateMins', type: 'enum', description: "Select the update frequency", title: "Update frequency (minutes)\n0 is disabled", defaultValue: '5', options: ['0', '1', '2', '5','10','15','30'], required: true
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
def logsOff() {
log.warn "debug logging disabled..."
device.updateSetting("logEnable", [value: "false", type: "bool"])
def updated() {
unschedule()
log.info "updated..."
log.warn "debug logging is: ${logEnable == true}"
if (logEnable) runIn(1800, logsOff)
if(updateMins != "0") {
schedule("0 */${updateMins} * ? * *", poll)
if (logEnable) log.debug(description)
def poll() {
if (logEnable) log.debug "polling..."
def url = "http://www.gmcmap.com/historyData-plain.asp?Param_ID=${GeigerID}&timezone=${Timezone}"
try {
httpGet(url) { resp ->
if (logEnable) log.debug resp.getData()
def respValues = new JsonSlurper().parseText(resp.data.toString().trim())
sendEvent(name: "CPM", value: respValues.CPM)
sendEvent(name: "ACPM", value: respValues.ACPM)
sendEvent(name: "uSv", value: respValues.uSv)
} catch(Exception e) {
log.debug "error occured calling httpget ${e}"
