Help with Schedule
Have I grossly misunderstood the concept of schedules in Rule Machine ... if so I do apologize. I simply want lights on and lights off at sunrise/sunset + offset every day. I cannot get this to work at all.
I would use simple lighting for this. If there are not a bunch of conditions, then set it up using simple lighting instead of rule machine. IMHO
Using a Rule here:
I'm sure there's different ways to do this but this works for me.
Using Simple Lighting:
Exactly! Let's not reinvent the wheel. Simple lighting is the win. Just my opinion.
Super simple with RM.
If time is between sunset + offset and sunrise + offset, turn on, else turn off.
I don't have offsets on this rule but it's the same concept.
I'm going to stick with @squidbilly here. While I see lots of times people want to show "other" ways of doing it...which IS great. I don't see why what he has shouldn't work. So I think there are 2 questions here.
  1. Why doesn't this work as is.
  2. What are ways can this be done.
#2 has been answered. I have rules using a schedule that work (they run custom commands) so why wouldn't his? Mine use a specific time, his is using "sunrise/sunset" maybe an issue there?
@squidbilly do you get any log entries at your specified times?
No, I don't see any log entries.
Thanks for all the help everyone.
I have had similar problems with simple RM apps. We couldn't figure out what the problem was until it was discovered that there seems to be a problem with having Days of the Week as Conditions. If you take that Condition out and instead set it as a Restriction, it should work.
