I'm really confused here.. I just want to have a rule that will arm my cameras when HSM status is armed home or armed away and disarm them when HSM status is disarmed.
Here's the rule:
When I change HSM to armed away or armed home - the cameras arm.. so that works. But, when HSM status is disarmed nothing happens.
You can see this in the logs.. notice how there's a bunch of logs after arming away (red) and then armed away (green). But, when the status is disarmed (yellow) - nothing.. ideas?
Thanks for your help! The only problem with that is I have delayed arming setup (not for any real reason though other than testing) -- so that would disarm when HSM status = "Arming Home" or "Arming Away" (the delay period).
From the logs it seems like "HSM status change to Disarmed" doesn't even trigger the rule (HSM status changed). I imagine I can also create 2 rules -- 1 just for HSM status = disarmed.. but, I was hoping to figure out why this particular rule isn't working
Yeah I agree - not sure why that isn't working for you. It definitely does work in several rules I have and the trigger is identical.
My alarm system does not integrate with HSM so I built my own integration. This rule triggers on HSM status like yours. When HSM changes to disarmed then I send a command to my alarm integration to disarm the alarm system. It definitely works
