It is 1:25am as I am reading this and I am groggy so I may be missing something, but I believe you have the on and off reversed as your original statement said you do not plan on using the toilet between 12 am - 6am.
However the rule you created is turning the toilet power on at 12am and off at 6am.
Ugh. Youāre totally correct. Iāve swapped it and am trying to run this rule starting at 4 am now. Canāt guarantee I had it right or wrong the first time.
Btw, I just recreated the rule. On the iPad at least, when you first choose the trigger and certain time, if you select AM for the first time it auto reverts back to PM after saving. Seems like a bug to me although it can somehow be iOS specific.
Ran a quick test. With the rule below, at 7:49 am the bidet/plug stayed on. 5 minutes later, it turned off and stayed off. I would have expected this to work.
Solved. Had the delay backwards. It shouldāve been associated with the āon.ā @bravenel I wish that RM read slightly differently as I find this order can be very confusing.
For example this to me (as a new user) makes more sense as it adds a wait (or delay if preferred) as a separate middle action to run:
Select trigger events
When time is 12:00 AM EST
Select actions to run
Off: Iris Plug Bidet
Wait: 6:00 AM EST
On: Iris Plug Bidet
Wait makes more sense than delay, and being able to specify an exact time would be handy.
Also, what the heck does that ācancelableā switch do when it appears next to delays???
