Help with Room Lightning
Hi,
I can't get to set up transitions in RL, I search the documentation and forums, but can't find how to set up.
This is for a Hue lamp connected through ' Advanced Hue Bridge Integration', and this is what I want to do:
  1. Start at 6:30PM at 10%
  2. Transition to 100% over 15 minutes (from 6:30PM to 6:45PM)
  3. At 9:00PM start transition to 20% over 15 minutes (from 9:00PM to 9:15PM)
  4. At 6:00AM in the morning, start transition to 100% over 30 minutes (from 6:00 AM to 6:30AM)
  5. At 8:00AM start transition to 0% (switch off) over 30 minutes (from 8:00 AM to 8:30AM)
Can this be achieved? Could anyone give some advise?
This is how I have set it up so far:
I believe RL doesn't allow you to specify different activation transition times for different periods. If you want to do it with a single instance, I think you'll have to pick a time and use it at each instance.
You could also make separate RL instances that trigger at different times, but you need to be careful with that, since they might sometimes fight for control of the lights.
Also, the transition will start at the indicated time, where the times in you post suggest those are the times you want the transitions to end.
Thank @mbishop, I believe you put me in the right track.
It seems to be working with this configuration (times are just samples for testing):
