Hi guys i have a button that controls a fan what i am trying to do is on a button controller when i push the button it will turn the fan button on for say 30 minutes
and each time i push the button it will increment the delay by another 30 minutes before it turns the fan off
I have it working with 1 push and it turns off after 30 minutes but would like to be able to push the button 3 times and it will run for 1h 30 minutes
I have searched and tried all sorts of things and can't figure it out, The old brain doesn't work as good as it used to
Any help would be much appreciated
Thanks in advance
I think something like this would work. Could get more complex depending on how you want additional button presses to extend the timer.
Ah cool i was starting to wonder if it was possible i will have a go at it tonight and see if i can get it working
Thanks for the help will let you know
Ended up doing it just now as kids canceled
Mate it works like a treat thank you so much
I owe you a beer
This is excellent. I would suggest another else if; counter = 4 cancel all and fan off.
I programmed another button on the remote to do fan of and it works
But as you say i will add that line so it cancels timer
But it does work well very happy with it
Love the HE came over from Vera edge
