No. If lights A or B are switched on between 18:00 and 20:30, I want a reminder to turn on C.
C stays on all night. Sometimes I do not want to turn on C. But I do not want to forget to turn it on, when I want it on. Hope it makes sense...
In Rule 4.0, the "Conditions" section does not do anything on its own. You can use them to build IF statements in your rule actions, which is how you actually check if your desired conditions are true. Your actions sections runs any time one of your triggers fire. Triggers are the only thing in Rule 4.0 that cause anything to happen (aside from things you've timed/scheduled in your actions, but those can only be set off by a trigger that caused them to run in the first place or the actions section itself being called by another rule).
I can help write one that might do what you want, but I want to make sure that this is what you want first: you want a speech notification every 10 minutes between 6 PM and 8:30 PM if Switch C isn't on but either (or both) A or B is? I would get quite annoyed if it was one of the times I didn't want C on. The above idea would probably work, but I don't know I'd want a job running every 10 minutes when I only care about it for a few hours a day--something that triggers at the desired start time then repeats every 10 minutes to check (and stops when C is on or the time is up) might be better.
Sometimes I go in and out of the room. Then I would turn on either A or B or both. It will be seldom that I spend more than 10 minutes. But if I do stay longer, I want to turn on C, but only when I want it on
Yeah, complicated, but it makes sense to me... Thanks anyway for thinking with me.
Here's another option that doesn't run every 10-minutes all day long. Instead, it only runs when switch A or B (Dimmer 1 or 2 in my rule) turns on, then checks to see if the time is between 1630 and 2200. If so, it notifies you every 10 minutes (after an initial 10-minute delay) if Switch C (Switch 2 in my rule) isn't on. It stops the repeats if the switch does get turned on or the time conditions are no longer met or if both A and B get turned off (at any time).
The rule is a bit "wordy" and I'm not super-happy about having to do some things twice (specifying "0:10:00" and "between 16:20 and 22:00"), and I might have too many (harmless) stops/cancels, but it's the best I could come up with at the moment and just really wanted to make sure the repeat never kept going when you didn't want it to--they can be tricky to work with. [EDIT: See below for a different user's suggestion on how to make this less wordy. Have I mentioned how much I hate repeats? ]
This also won't check at 16:30 if A or B is already on to see whether C is on. If you want that, adding "Time is 16:30" as a trigger should take care of that with no ill effects. There may be other things I haven't thought about, but hopefully this is a good starting point (I encourage competent adults to verify my work, as always).
Yeah, moving the end time and "Switch C changed" to the triggers allows that to be simplified quite a bit, doesn't it. So for the poster, I'd recommend that IF be something like IF (Switch A is on OR Switch B is on AND Switch C is off AND Time between 16:30 and 22:00), then that one ELSE should catch everything they want to cancel the repeat (and delay).
I don't understand your constant hostility. If the poster is not familiar with Rule Machine, the order of conditions in the IF matters since OR and AND are evaluated left to right with equal precedence, and changing the order would cause undesirable results. I just wanted to make sure that didn't cause any problems. Peace.
Thank you @Ryan780 and @bertabcd1234
Good ideas from both of you. At the moment I'm using the "every 10 minutes" rule, but I will look into your rules for sure!
One other quick question:
I understand the difference between AND and OR. Will OR be treated the same as the human and/or? In other words, if I use OR, will it also trigger if both lights are on?
Highly advise against this. Hubitat is an event driven system. 99% of the time this rule is going to do nothing but consume resources. This is not SmartThings where you have unlimited cloud computing power that you can use. There are only same many operations that the Hub can do in a given moment. Do you really want it tied up with something adding no value?
@Ryan780, I'm looking at your rule now. Unfortunately I'm not at home, so I cannot test it now.
I do not understand your REPEAT.
If conditions are met, after a delay, the Hubitat will speak.
Then it will repeat, but what exactly will repeat? Will checking the conditions repeat, or is it only going to repeat the speak part?
And it's stopable, but what exactly will stop it?
(Sorry if these are noob questions)
EDIT: Wait, I think I see it, if "Office Hue Strip" turns on, the whole rule will trigger again! Will this kill the first (repeating) instance of the rule? If so, I understand the rule completely.
