Help with new forum interface
I'll compare and see what I can do. Was focused on light theme. Dark theme is next.
Some sort of timing issue, that is on Discourse to fix.
Yeah, a refresh will fix it, but until you do it seems to remain consistantly off. Like I said, Minor
The new pastel green does not provide enough contrast with the white numbers. The color is hard on the older eyes. White lettering on green was fine with the previous shade of green.
I know, it bugs me to no end that they take a predefined template color and then randomly adjust the tone. We've been overwriting these forced adjustments one by one. If I make the secondary color very dark to compensate, then we end up with dark green in some places and still too light in others.
These are now available at the bottom of the menu:
It seems that you’ve made the changes to the Light mode/theme. Thank you.
Ugh. Sounds like an enormous amount of extra work.
Now I’ve found where Foundation is I’ve moved off dark mode and to Foundation and selected dark mode on there… I’m happy now
This has been the most challenging task LOL. Check it out, I think you'd like the changes.
I may be doing something wrong, but I can’t see any visual indication of the topics I have viewed completely and the ones I have not. I am using Microsoft Edge as the browser. I am on the foundation setting with dark mode enabled. The screenshot I attached shows a section of the forum and the only topic I have visited is the Username change request topic. As you can see there is no clear indication between any of them. If I open the forum on my iPhone the writing is white and the viewed topics are gray instead of them all being green.
The Foundation theme is WYSIWYG. They don't allow any customization.
i dont like the new edit mode for postings..
with images in your posting it now shows the image instead of the url which makes it hard to edit/delete them or move them around..
is there a way or setting to go back to just having the url shown when in edit mode?
thanks
Click here:
