I'm not sure why this isn't triggering. I have 3 separate rules going on to notify me if mail has arrived. The logs say everything happened right, but I am not getting the notification.
This rule should become true if motion is detected between 10am and 9pm. At that point it should set a private boolean for "Mailbox 2 Private Boolean" rule to true:
When this private boolean becomes true, it turns on a virtual switch, and sends a pushover notification. (but that didn't happen):
This resets the private boolean at midnight:
Logs seem to be correct...
app:8082018-08-25 19:05:08.641:infoNOTIFY: Mailbox 1 Rule is now False
app:8082018-08-25 19:05:08.601:infoNOTIFY: Mailbox 1 Rule: Mailbox motion inactive
app:8082018-08-25 19:04:53.110:infoNOTIFY: Mailbox 1 Rule is now True
app:8112018-08-25 19:04:53.077:infoNOTIFY: Mailbox 2 Private Boolean set Boolean from NOTIFY: Mailbox 1 Rule true
app:8082018-08-25 19:01:35.729:infoNOTIFY: Mailbox 1 Rule is now True
app:8082018-08-25 19:01:35.580:infoNOTIFY: Mailbox 1 Rule: Mailbox motion active
