I am porting a driver over from ST and everything seems to be working but I really like to understand what all the code is doing. This multiChannelCmdEncap stuff is one thing that is throwing me off. Part of the issue is all the back and forth between the hub and device, make it all more confusing. There is some sort of a workaround in this code also, which again seems to be working and I can actually see what it is doing in my command trace logging. But why... is this really a zwave bug or just a bad implementation that needed a workaround?
Other things is the Parent / child stuff. From what I can gather the child is basically just there so the extra "channel" (which is a second button on this switch) can be added to the dashboard as a switch and used in rules. So any of the events that happen on that channel I should send to the child. Some of the code I ported over just seems like it might be un-necessary but I don't know enough to determine that exactly.
I think I have all the other stuff pretty well nailed down from the other similar ports I did, and I also compared it heavily to the example Hubitat drivers and another driver for the same switches.
Any feedback, links to articles, other well made drivers I can peek at, whatever is appreciated. I can learn from reading instructions or looking at other code.
