Help with extreme laggy experience? C7
I have a very simple setup. C7 connected to 3 other switches. There is some distance since the others are in the back of my yard....maybe 40 feet away. I want the back-yard switch to turn on and off the others to light up my yard at night.
It works...but....I get delays up to 30 seconds. And different amounts of delay on each light.
What I have tried:
  1. Mirror. Super slow but works.
  2. Simple Group and Scene. Super slow but works.
  3. Z-Wave Association Tool. Have not been able to get it to work at all. The switch is newer but the others are old. Maybe a security incompatibility? I spent a lot of time on this.
  4. I put a spare Z-Wave outlet in the middle of our yard and then rebuilt the network thinking that might speed it up if it's a distance problem. No difference.
Any other suggestions? Thank you everyone!
are you using Z-wave Zip or JS? Post you entire Z-wave table screenshot (since you're new, you may need approval to post JPG's)
Ask @support_team to give you the ability to post screenshots
Welcome to the Hubitat community!
What brand and model are these switches? Try to be exact if at all possible, for example there are probably well over 5 variations of Jasco/GE/Enbrighten and they all have their own quirks.
Are they dimmers or switches?
These dimmers/switches all work quickly if you don't group them, like if you were to go to an individual device page, and turn the switch on?
I am using the classic Zip stuff. I didn't even know about the JS version until you just brought it up. It sounds like it is in early beta for the C7 device so I'll probably hold off on that. I think I may have found a solution but it will require me to buy a couple undated switches.
I tried posting my matrix but you are right. I don't have permissions yet.
I don't know all the exact versions of the switches unfortunately. I have some newer ZW15S devices but I think I have narrowed down part of the problem to two DZS15 devices. I was able to use the Association Tool to connect the back yard lights from a newer switch and now they turn on instantaneously. But I can't use the other switch I want to control them with because it apparently does not support associations. Or at least I have not been successful doing so.
But yes, if I turn lights on and off from the dashboard they flip quite quickly. But if I group them in any way and then do it....they lag badly.
I am going by memory, so please search, but I think there have been numerous firmware updates on these switches. I seem to recall people complaining about all sorts of issues with this model. And I think they are older (500 series Z-wave)?
I would look at Zooz, they have some really nice switches/dimmers that are 800 series Z-wave, and relatively inexpensive for the features you get.
So, this post has a link to joing the owners group (first link in the post), as well as quite a few useful tips for troubleshooting issues. Once you join the owners group, you should be able to post screenshots
