Greetings,
I have searched, read, & tried. Unfortunately...
Been trying to setup a rule that sends a Pushover, Emergency, when a room temp drops below 65. Does not work.
But it DOES work perfectly if I hit the "run actions" inside the rule.
I set my Android phone to all volumes off, and do not disturb. I had entered the values in the "retry" & "auto expire' in the Pushover driver (Push2Bill). I entered the [E] in the rule actions message. All works perfect when I say run actions.
To test, I changed the rule temperature from 65 degrees, to 80. I waited the 5 minutes, which I had set in the rule. No alerts get sent. The logs show no activity.
I'll post some screen shots below. Thanks very much for any assistance. Bill
When I hit the "run actions" here's the logs:
rom Logs:
dev:102025-01-11 03:33:28.244 PMinfo
Sending Message: [Art room temp less than 65 degrees. On Jan-11-2025 at 3:14 PM.] Priority: [2] to [All Devices]
app:5932025-01-11 03:33:28.219 PMinfo
Action: Notify Push2Bill: 'EArt room temp less than 65 degrees. On %date% at %time%.(EArt room temp less than 65 degrees. On Jan-11-2025 at 3:14 PM.)'
de
thank u.
If it works when you hit Run Actions, the actions aren't the problem. In your rule, that probably just leaves the trigger. Has the device sent an event and remained in the resulting state for the specified time? With your logging enabled, you should see something when a matching event comes in (even if it doesn't trigger), so those logs would give more clues. Be sure you've hit "Done" (or "Update Rule") since adding this trigger if you haven't.
As @bertabcd1234 says: Itās not enough that the temperature is currently under your threshold, you need to wait for a new temperature reading to come in from the sensor and as long as itās below 85 degrees for 5 minutes after that reading, the rule should trigger.
Excellent, thank you both for the instant, precise response.
OK. I think u guys are right.
I looked at the reporting from the motion sensor for temp (ZSE11). It's all over the map.
Sometimes 1 minute before temp reporting, a few times almost an hour!
logs"
dev:3482025-01-11 12:35:43.460 PM
info
Motion Craft Rm1: temperature set to 76.6Ā°F
dev:3482025-01-11 12:35:37.874 PM
info
Motion Craft Rm1: motion set to active
dev:3482025-01-11 12:32:42.988 PM
info
Motion Craft Rm1: temperature set to 77.3Ā°F
dev:3482025-01-11 12:29:42.324 PM
info
Motion Craft Rm1: temperature set to 78Ā°F
dev:3482025-01-11 12:20:40.689 PM
info
Motion Craft Rm1: temperature set to 78.6Ā°F
dev:3482025-01-11 12:17:40.130 PM
info
Motion Craft Rm1: temperature set to 77.9Ā°F
dev:3482025-01-11 11:49:35.791 AM
info
dev:3482025-01-11 11:42:57.593 AM
info
Motion Craft Rm1: motion set to inactive
dev:3482025-01-11 11:41:29.592 AM
info
dev:3482025-01-11 11:41:27.979 AM
info
dev:3482025-01-11 11:40:44.388 AM
info
dev:3482025-01-11 11:29:31.924 AM
info
dev:3482025-01-11 11:21:37.373 AM
info
dev:3482025-01-11 11:20:12.252 AM
info
dev:3482025-01-11 11:12:28.466 AM
info
dev:3482025-01-11 11:12:11.372 AM
info
dev:3482025-01-11 11:10:50.424 AM
info
dev:3482025-01-11 11:05:26.890 AM
info
dev:3482025-01-11 10:48:23.747 AM
info
dev:3482025-01-11 10:24:19.813 AM
info
dev:3482025-01-11 10:18:18.783 AM
info
dev:3482025-01-11 09:21:09.326 AM
info
dev:3482025-01-11 09:13:07.956 AM
info
dev:3482025-01-11 08:42:02.632 AM
info
dev:3482025-01-11 08:08:57.256 AM
info
dev:3482025-01-11 07:52:54.472 AM
info
dev:3482025-01-11 07:43:52.938 AM
info
dev:3482025-01-11 07:38:52.041 AM
info
dev:3482025-01-11 06:23:39.246 AM
info
sorry!
Didnt realize the paste would be like that!
The zse11 has very configurable reporting options for temp -- you can set it up pretty much however you want. Here are the options for 700/800 models:
https://www.support.getzooz.com/kb/article/1003-zse11-q-sensor-advanced-settings/
here's the preferences for the Motion / temp ZSE11:
Well, folks it worked!!!
Ooooo my! All afternoon I worked on it.
Jeeze.
Thank you ALL very much!
Now I have to see why there are big time spaces in the unit reporting.
I appreciate your time very much!
Bill
And... to sum it up to maybe help others:
With your help, I focused on the temp reporting. And previously, after I created my rule, the "Art" room's temp had not really changed past that small ZSE's preferences temp reporting degrees setting.
So, I guess ... no temp chance.. no ZSE reporting... no rule runs.
Thanks everyone!
Confirm it's working by putting your phone on silence. If emergency overide is working then it will still sound.
Yes Sir, it did. Thank u for checking.
I put all volumes off, then put on do not disturb, and received the noise.
Awesome!
