Since the bundle/libraries have come out, I been trying to figure out how to automatically download and install a bundle .zip file from GitHub.
But If I try to use a Post command, it seems to download but it doesn't install. @gopher.ny has stated that if downloaded, it will install on it's own.
There are no errors in log and I have no hub security enabled on this C-5, running the latest code.
Any ideas?
def installBundleHandler(bundle) {
if(logEnable) log.debug "----------- Start Install Bundle ----------"
if(logEnable) log.debug "In installBundleHandler (${state.version}) - ($bundle)"
try {
def params = [
uri: 'http://127.0.0.1:8080',
path: '/bundle/uploadZipFromUrl',
headers: [
"Accept": '/',
"ContentType": 'text/html; charset=utf-8',
body: [
source: bundle
// Example source: 'https://github.com/bptworld/Hubitat/raw/master/Bundles/Blank.zip'
timeout: 30,
ignoreSSLIssues: true
if(logEnable) log.debug "In installBundleHandler - Getting data ($params)"
httpPost(params) { resp ->
if(logEnable) log.debug "In installBundleHandler - Receiving file: ${bundle}"
if(logEnable) log.debug "In installBundleHandler - Hopefully installing Bundle"
} catch (e) {
log.error(getExceptionMessageWithLine(e))
tomw
October 3, 2021, 9:34pm
2
@Bago figured this out. I think maybe your body is wrong, but I haven't tested to confirm the correct form.
Bago
October 3, 2021, 10:04pm
4
@bptworld Have you tried using curl? Just as a test. Also, which version are you running?
No idea how to use curl. Running the latest Beta.
Bago
October 3, 2021, 10:17pm
6
Use the curl command I sent earlier. Just substitute in your values.
Much thanks to @bago . With his persistence, I now have working code. On to the next step! lol
This works...
try {
def params = [
uri: 'http://127.0.0.1:8080/bundle/uploadZipFromUrl',
headers: [
"Accept": '/',
body: bundle,
timeout: 30,
} catch (e) {
@gopher.ny , did something change with bundles? This doesn't seem to work anymore. No errors, just doesn't install.
example bundle:
Bago
May 4, 2022, 7:20pm
9
Give me a sec and I’ll send you the change.
@bptworld
The change is in the expected json (and it changed a month or two ago). I use python to push updates for my hubs, but here is the json:
jsonData = {
'url':url,
'installer':False,
'pwd':''
Thank you for the response but where does that go??
Thanks!
Bago
May 4, 2022, 8:17pm
11
In the post to the url, body content
It’s just a minor change from the original json required from before.
I was assuming it was the body content, but...
Bago:
I'm sorry, I'm just not following.
Bago
May 4, 2022, 8:24pm
14
Where you pass in bundle in the body, pass in the bundle using the newer format.
This should work - may have to add an import for groovy.json.JsonOutput in your code though
def jsonData = JsonOutput.toJson([url:"$bundle",installer:FALSE, pwd:''])
try {
def params = [
headers: [
"Accept": '*/*',
"ContentType": 'text/plain; charset=utf-8',
body: "$jsonData",
timeout: 30,
} catch (e) {
Thank you! I wasn't even close.
Edit: and it works!. Thank you both very much.
Possible error in Bundle Manager -
I was managing my hub - and trying to get BM to show all my Bundles. One, Follow Me, would not show as installed. The app was, but I had not yet installed any children.
Once I put a child in, BM showed/displayed the associated bundle.
For my apps, only the children send their info to BM. So no, that bundle won't show up unless you create one or more children.
system
Closed
June 13, 2023, 5:35pm
19
