Help with Device Driver/Polling
Question: I have a number of simple zwave plus outlets from a company called Dragon, Model PA-100. (I have attached pictures).
I paired with HE, without any difficulty as a generic z wave outlet, with the following data:
Data * deviceType: 17479
  • inClusters: 0x5E,0x86,0x72,0x5A,0x85,0x59,0x73,0x25,0x27,0x70,0x7A
  • deviceId: 12337
  • manufacturer: 388
    However, no matter what device type I changed it to, it doesn't seem to respond to a physical press, until I do a refresh on the device page. Unfortunately, I can't seem to select this device for polling.
    Anyone have any suggestions how I can make HE respond to the physical press of these units?
Not sure how to interpret their Conformance Statement:
https://products.z-wavealliance.org/products/1091/embedpics
"Lifeline association only supports the "manual reset" event. For instructions on how to “set lifeline associate” ,please refer to your wireless controller instructions. "
Lifeline association is what tells the device where to send the status reports. Yet this says it only offers "manual reset"
The confusing part is I don't understand how they'd get certification and thus permission to use the ZWave Plus logo, with only a partial compliance.
Are you sure it's Generic Z-Wave Outlet, and not Generic Z-Wave Smart Outlet? I was under the impression that all of the non-smart generic Z-Wave Switch/dimmer/outlet drivers were eligible for polling, but I've never tried to poll an outlet before so could be wrong about that one.
If Generic Z-Wave Outlet (non-smart) doesnt allow you to select for polling, you could try changing the driver to Generic Z-Wave Switch, which is available for polling. No idea if it would work but it's worth a shot.
Unfortunately, HE does not have a Generic Z-Wave Smart Outlet device handler.
I changed it to a smart switch, and it doesn't allow me to select it in the Polling program.
I also changed it to a generic zwave switch and it doesn't allow me to select it in the Polling program.
I think that's what I get for buying some stuff on sale! :joy:
However, it did work perfectly under ST.
Generic Z-Wave Switch should be available for polling. I have used it successfully before.
Sorry. You're quite correct. I changed it to a generic switch (even though its a zwave plus device), and I was allowed to select it to poll.
I hope that will make the "physical" presses show up.
I'm curious if outlet and switch are interchangeable from a digital command standpoint, and if polling will work. Keep us updated.
Ideally we'd figure out why physical events are not reported to begin with.
