I've managed to get Echo Speaks installed through HPM and received a announcement test through my Gen 1 Echo. But I've had trouble accomplishing the action I wish to have. We have 2 garage doors, each having a contact sensor which show status fine in Dashboard. I simply want the system, every night at 11pm to announce whether either of those 2 are still open. Its not a status change trigger; its a trigger based on time to announce contact open. Can anyone help with the correct config steps for this? I've only gotten an announcement to work upon a change in contact status. Thanks!
Have you tried doing this via Rule Machine?
Trigger: every day at 11pm
Action: Announce the door status
If you want something that only announces when the door is open and not shut, you can just add this to the above using a conditional:
Action: IF Door xyz contact is open Announce the door status
You can setup a echo speaks action based on scheduled time
so the action type should be 'speak' or some form of speak or announce
- name it and hit done/next
after you save it, go back to edit this action
the trigger is 'scheduled time'
- schedule type is recurring
- set your desired time
- recurring 'daily'
after next/done
the condition is your contact status
the execute action is the
- echo (s) or zones to send the message to
- and in the designer set the message you want to send
save/done your way out.
At the set time, it will wake up, check the contact condition and based on that send the message you put in execute.
Thanks, I think that is working but I have weird Echo behavoir. After I test once or twice, I can see the Echo light as active, but hear nothing. I have this often happen on its own before I installed this particular app as well. I have resorted to a daily power reset with a timed outlet which usually helps. But if this will also happen after each announcement, its a bummer. Any thoughts on why its doing this silence treatment?
