Cool! Excited to see where you end up.
I am trying to figure out why the Dashboard Thermostat capability does not show the Heating/Cooling Setpoints So you can adjust them.
My guess is you have to support all the commands defined in the thermostat device.
I think I am... I am done for the night but I will go through with a fine tooth comb again.
Capabilities too maybe?
For temperature control to Google Assistant, you have to comply with the specific device traits.
https://developers.google.com/assistant/smarthome/traits/temperaturesetting
I got the device to show up in Google home, but it is pretty useless because it doesn't allow control as high as a water heater is set.
What I am struggling with now is getting the setpoint controls to show on the hubitat dashboard for thermostat.
I see this section in the API.
thermostatTemperatureRange
Object. Optional. Contains two float values that indicate the supported minimum and maximum temperature range for this device (in degrees Celsius):
minThresholdCelsius
maxThresholdCelsius
But how do I present this to Google? It looks like it could fix my problem.
These present as the top and bottom of the range that the thermostat can be set to. I don't believe this is what you are looking for.
Try updating the app and driver and let me know if there is any improvements.
@mike.maxwell Do you know why my thermostat dashboard tile does not show the increment decrements buttons?
Here is my furnace which is working:
Here is my water heater which is NOT working:
Broken app and driver are located here:
Brian,
I don't know if you remember this, but your previous driver was broken for the newer Gen 4 HPWH. From this previous post of mine, it has the fixes for the newer model. Is there a way to incorporate this into your driver?
I realize it adds some complication, but it would be nice if we didn't have to find/replace a bunch of things every time you update the driver.
I have looked at your app/driver many times in the past year or so, and compared it to many other HVAC code sources, and I also cannot find anything obvious that would make the dashboard not work correctly. I am completely awful with code, but I can copy and paste with the best of them. Hopefully you can get some guidance from Mike or someone else to fix this.
First, I made the edits to the code as I noted in the linked post above. Wow, this new code sure is quick to respond! I change states in Hubitat, and it nearly simultaneously changes in the phone app. At a quick glance, everything seems to work fine except the dashboard.
I can't be certain, but your driver uses several overlapping capabilities, it really only needs thermostat and temperature measurement. All the other thermostat capabilities aren't needed.
