Help with 2 gang tuya switch
I have a tuya 2 gang switch i'm trying to get configured to work in HE
  • endpointId: 01
  • application: 42
  • inClusters: 0001,0500,EF00,0000
  • manufacturer: _TZ3210_3ulg9kpo
  • model: TS0021
  • outClusters: 0019,000A
  • softwareBuild:
I have tried using Moes Zigbee driver but it hasn't worked for me.
Hello,
Just received the same device! :frowning:
Was you able to get it working?
Hi @user2912 ,
Is your device this one?
( AliExpress link )
You can try this Tuya Zigbee Button driver.
It is a bit confusing what is a button and what is a scene switch and what is the difference from a 'true' swithc - different tems used by different manufacturers. But the TS004F driver should be the right one for this device. Pair the 2 button scene switch again to the hub after installing the custom driver first.
Thank you :heart_eyes:
Working now with this driver.
