Help! Unresponsive UtraPro switch
Hello:
Last night, one of the lights did not turn off with my nightly routine. Tried to turn it off from the physical switch but it is completely unresponsive. It appears to be the only device that is malfunctioning so I don't think this is a hub issue.
In the Z-Wave details page, I clicked on "Refresh" and it's been in "Pending" status since last night. I don't think the UltraPros have anything on the switch itself to reboot it, so is my only option to turn it on/off from the breaker? I have quite a few of these switches and this is the first one that has misbehaved.
If I have to replace the switch, do I exclude this switch (the paddle is not working so not sure if exclude will work) or should I try replace when including the new switch or try the "remove" from the Z-wave details page.
Thanks for your help.
There is an air gap tab on the bottom. Have you pulled it out yet?
I thought these did not have an air gap tab :man_facepalming:t2:. That worked - thanks!
Have you had a power outage recently? The capacitors on some of the earlier versions did not handle coming back to life when the power returns.
No power outage - pulling out the air gap tab fixed it.
All my 2017 vintage Jasco switches failed because of this. Jasco is the brand behind GE and UltraPro.
I have been using Jasco switches since I got into HA in 2014 and from time to time I had to either air gap or cycle a breaker to fix a stubborn switch. If this continues you might want to check for updated firmware on Jasco's Github.
