My rule machine skills are poor, and I don't know how to work with local variables - assuming they would even be applicable in this case.
I have ~10 zigbee outlets (A,B,C,D,E,F,G,H,I,J) that I want to leave on. How do I create a rule that will turn a specific outlet from a list of 10 back on.
What I can create in rule machine is that if any of the 10 turns off, a "turn on command" is sent to all 10. Or I can create a IF/THEN-ELSEIF/THEN-ELSEIF/THEN-....ENDIF chain with an ELSIF/THEN pair corresponding to each outlet.
But there's probably a simpler way to achieve this. Something like if any of the ten outlets turn off, put the name of that outlet into a variable, and then turn the variable back on.
Can someone help me? Please. I want my rules to become more efficient.
Thanks!
