I have an inovelli LZW31 black series dimmer directly associated with 4 inovelli color bulbs LZW42, sometimes it works instant sometimes its slow.. i need help reading the logs to see if there is any unusual behaviour..
When i turn the lights on via the switch this are the logs
dev:12582021-11-07 05:29:13.238 pm debugSwitchMultilevelReport(value:99)
dev:12582021-11-07 05:29:13.235 pm debugparse:zw device: 3F, command: 2603, payload: 63 , isMulticast: false
dev:12592021-11-07 05:29:12.034 pm debugSwitchMultilevelReport(value:99)
dev:12592021-11-07 05:29:12.031 pm debugparse:zw device: 40, command: 2603, payload: 63 , isMulticast: false
dev:12592021-11-07 05:29:11.863 pm debugSwitchMultilevelReport(value:99)
dev:12592021-11-07 05:29:11.860 pm debugparse:zw device: 40, command: 2603, payload: 63 , isMulticast: false
dev:12592021-11-07 05:29:11.856 pm debugSwitchMultilevelReport(value:99)
dev:12592021-11-07 05:29:11.853 pm debugparse:zw device: 40, command: 2603, payload: 63 , isMulticast: false
dev:12592021-11-07 05:29:11.767 pm debugSwitchMultilevelReport(value:99)
dev:12592021-11-07 05:29:11.764 pm debugparse:zw device: 40, command: 2603, payload: 63 , isMulticast: false
dev:12582021-11-07 05:29:11.742 pm debugSwitchMultilevelReport(value:99)
dev:12582021-11-07 05:29:11.740 pm debugparse:zw device: 3F, command: 2603, payload: 63 , isMulticast: false
dev:12582021-11-07 05:29:11.661 pm debugSwitchMultilevelReport(value:99)
dev:12582021-11-07 05:29:11.658 pm debugparse:zw device: 3F, command: 2603, payload: 63 , isMulticast: false
dev:12592021-11-07 05:29:11.610 pm debugSwitchMultilevelReport(value:99)
dev:12592021-11-07 05:29:11.607 pm debugparse:zw device: 40, command: 2603, payload: 63 , isMulticast: false
dev:12592021-11-07 05:29:11.536 pm debugSwitchMultilevelReport(value:99)
dev:12592021-11-07 05:29:11.533 pm debugparse:zw device: 40, command: 2603, payload: 63 , isMulticast: false
dev:12582021-11-07 05:29:11.316 pm debugSwitchMultilevelReport(value:99)
dev:12582021-11-07 05:29:11.313 pm debugparse:zw device: 3F, command: 2603, payload: 63 , isMulticast: false
dev:12572021-11-07 05:29:11.152 pm debugSwitchMultilevelReport(value:99)
dev:12572021-11-07 05:29:11.149 pm debugparse:zw device: 3E, command: 2603, payload: 63 , isMulticast: false
dev:12582021-11-07 05:29:10.889 pm debugSwitchMultilevelReport(value:99)
dev:12582021-11-07 05:29:10.886 pm debugparse:zw device: 3F, command: 2603, payload: 63 , isMulticast: false
dev:12872021-11-07 05:29:10.846 pm debugSwitchMultilevelReport(value:99)
dev:12872021-11-07 05:29:10.843 pm debugparse:zw device: 41, command: 2603, payload: 63 , isMulticast: false
dev:12872021-11-07 05:29:10.662 pm debugSwitchMultilevelReport(value:99)
dev:12872021-11-07 05:29:10.650 pm debugparse:zw device: 41, command: 2603, payload: 63 , isMulticast: false
--- Live Log Started, waiting for events ---
and this happens when i turn the lights off
dev:12592021-11-07 05:35:48.762 pm debugSwitchMultilevelReport(value:0)
dev:12592021-11-07 05:35:48.759 pm debugparse:zw device: 40, command: 2603, payload: 00 , isMulticast: false
dev:12582021-11-07 05:35:47.864 pm debugSwitchMultilevelReport(value:0)
dev:12582021-11-07 05:35:47.862 pm debugparse:zw device: 3F, command: 2603, payload: 00 , isMulticast: false
dev:12592021-11-07 05:35:47.830 pm debugSwitchMultilevelReport(value:0)
dev:12592021-11-07 05:35:47.828 pm debugparse:zw device: 40, command: 2603, payload: 00 , isMulticast: false
dev:12582021-11-07 05:35:47.700 pm debugSwitchMultilevelReport(value:0)
dev:12582021-11-07 05:35:47.697 pm debugparse:zw device: 3F, command: 2603, payload: 00 , isMulticast: false
dev:12582021-11-07 05:35:47.566 pm debugSwitchMultilevelReport(value:0)
dev:12582021-11-07 05:35:47.563 pm debugparse:zw device: 3F, command: 2603, payload: 00 , isMulticast: false
dev:12582021-11-07 05:35:47.274 pm debugSwitchMultilevelReport(value:0)
dev:12582021-11-07 05:35:47.271 pm debugparse:zw device: 3F, command: 2603, payload: 00 , isMulticast: false
dev:12592021-11-07 05:35:47.099 pm debugSwitchMultilevelReport(value:0)
dev:12592021-11-07 05:35:47.096 pm debugparse:zw device: 40, command: 2603, payload: 00 , isMulticast: false
dev:12582021-11-07 05:35:46.920 pm debugSwitchMultilevelReport(value:0)
dev:12582021-11-07 05:35:46.917 pm debugparse:zw device: 3F, command: 2603, payload: 00 , isMulticast: false
dev:12572021-11-07 05:35:46.735 pm debugSwitchMultilevelReport(value:0)
dev:12572021-11-07 05:35:46.732 pm debugparse:zw device: 3E, command: 2603, payload: 00 , isMulticast: false
dev:12872021-11-07 05:35:46.605 pm debugSwitchMultilevelReport(value:0)
dev:12872021-11-07 05:35:46.599 pm debugparse:zw device: 41, command: 2603, payload: 00 , isMulticast: false
Everything works as it should but I notice some devices send repeated messages most of the time , Is this normal ?
all 4 bulbs are on same inovelli driver,latest firmware ect .
