This is my first time using Hubitat and I am trying to make my first rule. A very straightforward lighting automation. I would think it is fairly easy but don't see how to do it. Would like to use the Simple Automation Rules and not Rules Engine because it is a pretty simple rule. Or should be anyways!
Here is what I am trying to accomplish:
- Turn on a Dimmer switch at 75% power 5 minutes after Sunset
- Turn it off at 11:00pm
I cant see how to do this without creating two separate rules - One to turn on the light and one to turn it off. If I was not using sunset as a the trigger but rather just a time of day, it looks like there is a place to also set what time I want to turn it off. But when I select Sunset, the field to turn the light off at a specific time goes away. Am I going crazy?
This is how most of my outdoor lights will be automated so any help would be appreciated. There must be a way to do this in a single rule?
