Help... Newb... Can't sign in
Newb with minimal technological knowledge here...
I installed the nest integration for my thermostats - which went fine. Then I updated to the latest version and when it was rebooted, tried to sign in and couldn't.
Changed the password. Nope.
Went to 8081 and restored to previous versions and still can't sign in.
At a loss here.
Thanks in advance.
So - was using chrome. signed in with MS Edge and was able to get in.
Any idea why?
Clear chrome's cache and that should fix you
Are you talking about hub UI sign-in?
If you signed in over HTTPS at some point, going back to HTTP requires clearing cookies for the hub's IP address (not global - that will sign you out of everything).
Yes - UI Sign-in. Thanks, fellas! That's it!
