Have pulled power twice - no luck, stays blue light.
Pressed little reset button on bottom for 15 seconds, with power on, no change. Find my hub reports the same IP address as always. Is it getting that from the Hub?
I have Hub Protect on this hub, but really hoping I can get this up and running without replacing it.
Odd - I plugged in a spare C7 and it only shows a blue light also. Could I have a bad port in my router? I just moved the cable to a different port and still only a blue light on the space C7.
Nope - could not connect to 8081. My guess is the router had a glitch and would not connect to the base IP address of the C7, Anyway it's okay now - thanks again.
