I go into webcore and select to add a device
and click update
then
done
when I go back into that piston - its not added
this is the same for any piston or device : (
and click update
then
done
I tried doing HPM repair but that did not help
You donโt add devices to pistons, you add them to the webCoRE app. Adding the devices to webCoRE makes them available inside pistons for triggers, actions, etc.
Thanks so much... I appreciate the help
that worked much better! I thought I was going crazy : )
It seems extra confusing to allow that option within a piston ......
