I thought it was working again because the switch(es) were making contact, and the sensor was also responding. But suddenly, it went wrong again—nothing worked anymore. I have now done a soft reset and restored the database from this morning at 09:00.
A question: how long should it take for the PRO8 with 8 Zigbee devices to be fully operational again, considering it only has a few simple rules like "if this, then that"? Because I have the impression that this is taking an extremely long time.
For example, when I try to turn a Hue lamp on or off via the devices section, it says the command was sent, but the lamp does nothing. The same applies to the switch and everything else.
I do see (some) Zigbee environment in the Zigbee graphical interface.
and strange thing is when i check te log when i push a button etc.
i see the the button is recieved but Hubitat does NOTHING with it??
and the devices are seen also by Hubitat:
i cant understand this issue?
