Hello:
Has anyone gotten this device to work with a non-RGBW LED? I am trying to make this work with a White (Warm/Cool) LED strip and while the device pairs, it will not control the LED. I have tried the Advanced RGBW (default when paired), Generic RGB Light but nothing works. I even tried the custom driver in this thread (https://community.hubitat.com/t/release-gledopto-gl-c-601p-pro-max-5-in-1-cct-tunable-white-driver/) but that did not work either. I know the wiring is correct because I can hold the "reset" button down and the LED will blink when the device is reset. Any help would be appreciated - thanks!
@mike.maxwell does this driver need updates or a dedicated driver for these newer Gledopto?
Well - I asked Gemini to create a driver specifically for my use and after a few rounds (the first one version it created worked but I had a few nits), it got me this version that is pretty close to what I want. If anyone has a similar need, feel free to use/improve it!
* Gledopto CCT LED Controller (Hubitat Custom Driver)
* Provides local control for Tunable White (CCT) LED strips.
metadata {
definition (name: "Gledopto CCT LED Controller", namespace: "custom", author: "Community") {
capability "Actuator"
capability "Switch"
capability "SwitchLevel"
capability "ColorTemperature"
capability "Configuration"
capability "Refresh"
attribute "colorName", "string"
command "setColorTemperature", [[name: "kelvin", type: "NUMBER", description: "2700 = Warm White | 3000 = Soft White | 4000 = Neutral White | 5000 = Cool White | 6500 = Daylight"]]
fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008,0300", outClusters: "0019", manufacturer: "GLEDOPTO", model: "GL-C-008P", deviceJoinName: "Gledopto CCT Controller"
preferences {
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: false
if (logEnable) log.debug "Parsing description: ${description}"
def event = zigbee.getEvent(description)
if (event && event.name == "colorTemperature") {
def clampedKelvin = Math.max(2700, event.value.toInteger())
event.value = clampedKelvin
event.descriptionText = "${device.displayName} color is ${clampedKelvin}K"
sendEvent(event)
sendEvent(name: "colorName", value: calculateColorName(clampedKelvin))
return
if (event) {
sendEvent(event)
} else {
def cluster = zigbee.parse(description)
if (cluster && logEnable) log.debug "Cluster parsed: ${cluster}"
private String calculateColorName(kelvin) {
def k = kelvin.toInteger()
if (k < 2400) return "Warm Amber"
if (k < 3200) return "Warm White"
if (k < 4500) return "Neutral White"
if (k < 5500) return "Cool White"
return "Daylight"
def on() {
if (logEnable) log.debug "Sending ON command"
sendEvent(name: "switch", value: "on")
zigbee.on()
def off() {
if (logEnable) log.debug "Sending OFF command"
sendEvent(name: "switch", value: "off")
zigbee.off()
def setLevel(level, duration = 1) {
def targetLevel = Math.max(0, Math.min(100, level.toInteger()))
sendEvent(name: "level", value: targetLevel)
if (device.currentValue("switch") == "on") {
if (logEnable) log.debug "Setting level to ${targetLevel} while ON"
return zigbee.setLevel(targetLevel, duration.toInteger())
} else {
if (logEnable) log.debug "Updated level to ${targetLevel} in background (switch is OFF)"
return []
def setColorTemperature(kelvin) {
def targetKelvin = Math.max(2700, Math.min(6500, kelvin.toInteger()))
def name = calculateColorName(targetKelvin)
sendEvent(name: "colorTemperature", value: targetKelvin)
sendEvent(name: "colorName", value: name)
if (logEnable) log.debug "Setting color temperature to ${targetKelvin}K (${name}) while ON"
return zigbee.setColorTemperature(targetKelvin)
} else {
if (logEnable) log.debug "Updated color temperature to ${targetKelvin}K (${name}) in background (switch is OFF)"
return []
def refresh() {
if (logEnable) log.debug "Refreshing device status"
return zigbee.onOffRefresh() + zigbee.levelRefresh() + zigbee.colorTemperatureRefresh()
def configure() {
if (logEnable) log.debug "Configuring Zigbee reporting"
return zigbee.onOffConfig() + zigbee.levelConfig() + zigbee.colorTemperatureConfig() + refresh()
