When I mentioned Soft-Reset on the old C8 hub as a troubleshooting step, please note I did not mention restoring a backup file as part of that process. I was suggesting that the hub be pretty close to factory reset, just to hopefully prove that it is something that is part of your hub's current configuration that is leading to the every 4 day crash issue... If the C8 does not crash after a soft-reset, then you could restore a recent backup from it, and see of the 4 day crashing resumes. If it does, then start removing, not just disabling, apps to see if you can pinpoint what is causing the crash. This way, you can hopefully discover the root cause without disrupting your product C8Pro hub.
Worth a try, although I would have expected the C8 Pro to resolve the issue if this was the case, since nothing would be running after I soft reset the C8. So if it were to reboot itself at that point I would think hardware would be the problem. Unless you were thinking something on the network could be causing a potential conflict, which would affect the hub in some way despite the current configuration.
I was thinking of just starting with the C8 on the network with just the radio's disabled.
Just hold on until the next beta release, unless your hub's performance is taking a hit and your experience is poor.
Okay I will wait.
