Quick question. Is there a central page or dashboard that would provide performance status on the on a single view.. Am looking for Memory ute's, CPU, I/O type stats... Have 2 HE hubs and one appears to be significantly sluggish....
Two things you can try. To take a look at the hub overall try @thebearmay's Hub Info driver. If you want to break down some usage stats by app/driver go to the logs page and look at the device stats and app stats tabs. The latter is mostly focused on CPU but will definitely help you track down something using a lot of resources.
appreciate it - thx
