If I edit the start time and enter a new value it does update but minus 1 hour. For example if I enter 2am it will display 1am, etc. End time seems to be working fine.
Did your hub update its time properly for Daylight Saving Time? Try waiting and editing the rule in another 24 hours. I believe sometimes the hubs do weird things when DST starts and ends.
Good thought. Hub time looks good. May only be this one rule. Still checking.
Nope, its happening in other places.
Is it because I am configuring a time range that extends before the time change today? For example I just added this between two times to this rule. I entered 12am which is before the time change and it displayed it incorrectly. Yet if I enter 4am it records it fine.
Itās possible. Iād wait 24 hours, like suggested above, and try again. If it still isnāt right after, then report back.
Yet another reason to get rid of the time change
If youāre still having problems, Iād change the logic to time is not between 10am and 11pm. Not sure about rule machine, but I believe in webcore, it will try to evaluate your statement as: if time is between 11pm today and 10am today.
I believe what youāre looking for is to evaluate if the time is between 11pm today and 10am tomorrowā¦ or in other words if the time is not between 10am today and 11pm todayā¦ or similarly - not between 10am any given day and 11pm that same day.
It seems to have corrected itself. So it appears the issue only shows on the day of the time change.
